Hello
Can the limits of an input value be made as a formula?
If you have a "Length" value can you then use this as a limit for another value.
"Width" may have a minimum of "150mm" and a maximum of "Length-150mm"
Solved by Marty700. Go to Solution.
Sorry, expressions are not currently supported in the Configurator 360 interface. Of course, you can have iLogic rules in Inventor check & enforce these limits.
Sanjay-
Sanjay
No worries, thanks for the prompt reply
Maybe something for the wish list?
Marty
