Configurator 360 General Discussion
Active Contributor
DPolsky-VAH
Message 1 of 3 (177 Views)
Increase Resolution for Picture Downloads
177 Views, 2 Replies
07-02-2014 07:54 AM
The resolution for a download seems to be set at 96 dpi, anyway to increase this?
Daniel
Hi Daniel --
Unfortunately, there is no option at this time.
Eventually, we will expose all the options of all the output-types.  One big question in my mind is how/if to expose options to end-users.  I think we can give the admin-user fine-grained control over this, but it will make the interface more complicated.
--Jon
Board Manager
Jon.Balgley
Message 2 of 3 (171 Views)
Re: Increase Resolution for Picture Downloads
07-02-2014 09:55 AM in reply to: DPolsky-VAH
Hi Daniel --
--Jon
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Active Contributor
DPolsky-VAH
Message 3 of 3 (165 Views)
07-02-2014 10:39 AM in reply to: Jon.Balgley
Thanks for the quick reply.
I would recommend one global resolution variable for image types at the admin level.  That way the admin interface isn’t cluttered up with settings for all the various image types Configurator provides.  Perhaps just label a field “Image Output Resolution”, default the field to 96, and let the admin user input an integer from 72 to a maximum value (perhaps 300).  Of course you could also make that field a drop down and give a list of resolutions for the admin user to select if you wanted to keep it simple.
