The resolution for a download seems to be set at 96 dpi, anyway to increase this?
Daniel
Solved by Jon.Balgley. Go to Solution.
Hi Daniel --
Unfortunately, there is no option at this time.
Eventually, we will expose all the options of all the output-types. One big question in my mind is how/if to expose options to end-users. I think we can give the admin-user fine-grained control over this, but it will make the interface more complicated.
--Jon
Thanks for the quick reply.
I would recommend one global resolution variable for image types at the admin level. That way the admin interface isn’t cluttered up with settings for all the various image types Configurator provides. Perhaps just label a field “Image Output Resolution”, default the field to 96, and let the admin user input an integer from 72 to a maximum value (perhaps 300). Of course you could also make that field a drop down and give a list of resolutions for the admin user to select if you wanted to keep it simple.
