Configurator 360 Forum (Read Only)
Welcome to Autodesk’s Configurator 360 Forums. Share your knowledge, ask questions, and explore popular Configurator 360 topics.
ChrisAtherton
499 Views, 1 Reply
Error on upload
Hi All,
I'm trying to load some client data to configurator360 to test its effectivness with their iLogic data.  I thought I'd start with a single part file, but when its uploaded the administrator list shows the error: Failed to check the saved software version.
The file had been created in 2015 so not sure why its not picking it up correctly.  I've attempted to rebuild the file on several machines using task scheduler with no luck.  I'm open to any suggestions if anyone else has some?
Chris
Chris Atherton
IEng MIMechE BEng Hons
Design Automation Services Manager | Symetri
https://uk.linkedin.com/in/chrissoathe
1 REPLY 1
Jon.Balgley
in reply to: ChrisAtherton
This is a poor error message on our side.  It means we got some kind of error while trying to determine the version, so it doesn't tell you what the problem is.
Can you send the file to us?  Send it to configurator360.support@autodesk.com
Jon Balgley
