Question, will Configurator 360 not work on a mac at all? or if it will can someone direct me to what needs to be downloaded to be able to use it.
Thank you,
Matthew
Solved by Jon.Balgley. Go to Solution.
Unfortunately, at this time, the "configuration page" (the important part) of Configurator 360 will not work on Macs.
We have a companion iPad app that you can use, but that's not the same thing as a Mac, of course!
The Configurator C360 administrator UI should work OK on Macs.
Of course, we are aware of this deficiency...
Thank you John! That is what i assumed, but I just wanted to make sure.
Thank you,
Matthew
