After updating my graphics card driver this morning, I get this error when trying to access an embedded configurator...
Reload (sometimes twice) will get the configurator on screen. Here are the graphics details...
Solved by MRanda. Go to Solution.
If you're running OK now, feel free to ignore this.
* What browser are you using, and have you / can you try another browser? (Chrome / Firefox / IE)
* Do you get the same error on other websites, e.g.,
http://threejs.org/examples/#webgl_geometry_shapes
* If you're using Chrome, and still having the problem, please send us the output shown by going here:
chrome://gpu/
Dear Jon, this is the result of my Chrome://gpu/
Data exported | 4/10/2016 11:44:58 |
Chrome version | Chrome/53.0.2785.143 |
Operating system | Windows NT 10.0.14393 |
Software rendering list version | 11.7 |
Driver bug list version | 8.93 |
ANGLE commit id | c9e893119842 |
2D graphics backend | Skia |
Command Line Args | Files (x86)\Google\Chrome\Application\chrome.exe" --flag-switches-begin --enable-fast-unload --enable-webgl-draft-extensions --show-autofill-type-predictions --flag-switches-end |
Initialization time | 0 |
In-process GPU | true |
Sandboxed | false |
GPU0 | VENDOR = 0x8086, DEVICE= 0x29c2 |
Optimus | false |
AMD switchable | false |
Desktop compositing | Aero Glass |
Diagonal Monitor Size of \\.\DISPLAY1 | 21.9" |
Driver vendor | Intel Corporation |
Driver version | 8.15.10.2697 |
Driver date | 10-1-2012 |
Pixel shader version | |
Vertex shader version | |
Max. MSAA samples | |
Machine model name | |
Machine model version | |
GL_VENDOR | |
GL_RENDERER | |
GL_VERSION | |
GL_EXTENSIONS | |
Disabled Extensions | |
Window system binding vendor | |
Window system binding version | |
Window system binding extensions | |
Direct rendering | Yes |
Reset notification strategy | 0x0000 |
GPU process crash count | 0 |
Tile Update Mode | One-copy |
Partial Raster | Enabled |
ATC | Software only |
ATCIA | Software only |
DXT1 | Software only |
DXT5 | Software only |
ETC1 | Software only |
R_8 | Software only |
BGR_565 | Software only |
RGBA_4444 | Software only |
RGBX_8888 | Software only |
RGBA_8888 | Software only |
BGRX_8888 | Software only |
BGRA_8888 | Software only |
YVU_420 | Software only |
YUV_420_BIPLANAR | Software only |
UYVY_422 | Software only |
Sorry to hear you having problems with C360.
Could you confirm that C360 (and WebGL) are worked before in Chrome?
Do you see WebGL problems if you open C360 model in FireFox or IE/Edge?
Could you check if WebGL works for https://threejs.org/examples/#webgl_geometry_shapes?
If it worked before and works in other browsers, I suspect it could be something with Chrome, like - https://productforums.google.com/forum/#!topic/chrome/MFwE-60chtY. Could you try the suggested workaround? (it was Mac-specific, but still worth to check)
Could you also execute dxdiag (just type it in console or in Win-R window), click Save All Information and send it to configurator360.support@autodesk.com?
Eugene Rymski
