Tool Orientation Missing
AmishSolanki
Message 1 of 46
AmishSolanki
I recently noticed that tool orientation is missing. This seems to be recent, as of my renewal to 360 (maybe has something to do with F360 Ultimate no longer a option?).
I've tried all different CAM tool path options and don't see it anywhere.
SS CADCAM - www.sscadcam.com
@sscadcam
Replies (45)
Message 2 of 46
dave.anderson
This was brought up to the developers, and they are looking into it.
Dave Anderson
Sr. Support Engineer– CAM
Message 3 of 46
jeff.walters
Are you talking about the WCS orientation in the Setup, view tool orientation that we don’t currently have in the system, or the Tool orientation on the bottom of the geometry tab? Are you on a MAC or a PC?
Jeff Walters
Senior Support Engineer, CAM
Message 4 of 46
AmishSolanki
Hi Jeff,
Yup talking about the tool orientation on the bottom of the geometry tab. It use to be there, but is no longer there. Running on a PC.
@sscadcam
Message 5 of 46
Lonnie.Cady
did your Ultimate trial expire and revert back to standard by chance?
Message 6 of 46
AmishSolanki
That's what I'm wondering what happened as well.
When I was looking online however, from everything I can read, that Fusion 360 and Fusion 360 Ultimate were combined back in July 2015? When my renewal was up, I went online and signed up for a year term, but was only given the option for Fusion 360 (nowhere could I find Ultimate option) so I just assumed it was be kept the same.
@sscadcam
Message 7 of 46
Steinwerks
If you click the question mark in the top right, and select About the resulting window should tell you whether you have Ultimate or not.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 8 of 46
AmishSolanki
Yeah, it only says Fusion 360. Seems like it reverted to the regular version, but I don't see anyway to upgrade back to Ultimate?
@sscadcam
Message 9 of 46
Laurens-3DTechDraw
I don´t think 3+2 was ultimate only.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 10 of 46
Lonnie.Cady
@Laurens-3DTechDraw I am pretty sure it is only in ultimate.
Message 11 of 46
Lonnie.Cady
I think they need to revist this page https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
they say 3+2 is ultimate but the graphic show it under standard.  Probably a little confusing.
Message 12 of 46
Laurens-3DTechDraw
Since there is no Ultimate for the time being all previously Ultimate features are now in standard as well:
But that still makes it weird that he doesn't see the tool orientation.
Laurens Wijnschenk
3DTechDraw
Message 13 of 46
Lonnie.Cady
@Laurens-3DTechDraw
That image you have is how old now?  I am sure it was accurate at the time.   But I am pretty sure I saw it mentioned else where that the standard versoin does not have tool orientation.  I could be wrong.   The image you show was accurate at the time the release was made to combine the products.  I am not sure it was going to apply for ever.  They have made it clear there will be an ultimate version and will have different features.
They probaby can't get that info straight until the new tool library is done or maybe it is the replatform I can't remember.
Message 14 of 46
Laurens-3DTechDraw
I would assume that image to be correct until Ultimate is available for purchase again.
Pick whichever you like best.Smiley Wink
Laurens Wijnschenk
3DTechDraw
Message 15 of 46
Lonnie.Cady
I'll go with tool library on this one,  Just incase it ever comes up again we can be on the same page.
Message 16 of 46
HughesTooling
This page seems to indicate 3+2 is for Ultimate only.
Fusion-360-Packaging-FAQ
Mark
Mark Hughes
Owner, Hughes Tooling
Message 17 of 46
Lonnie.Cady
I misread the graphic.
I agree @HughesTooling that is the same link I posted above.
Message 18 of 46
srinath_jonnalagadda
Hello @Lonnie.Cady & @HughesTooling,
I confirm that 3+2 axis is in Ultimate.
@AmishSolanki - could you please send me a PM so that i can work out a way to get you access to 3+2 axis?
Cheers,
-srinath
Message 19 of 46
@Lonnie.Cady
You were right.
There are differences again between Ultimate and "Normal/Standard".
So I guess a lot of people will miss out on this because they have no idea Ultimate exists. It's now where on the autodesk site without doing serious digging.
So they will just buy Fusion 360 subscription without knowing you can get Ultimate through a re-seller.
Laurens Wijnschenk
3DTechDraw
Message 20 of 46
Lonnie.Cady
@Laurens-3DTechDraw
I am sure they will get it figured out.  But until they do decide what they are doing it is confusing for some potential customers.  I have ultimate early adopeter pricing so it does not really matter to me either way.  When things are in a state of change or uncentainty it does not instill confidence in people.  I would think people who are making decison about their business and its future with fusion would want a clear path as to what is going to be in the final product.  But if I am a hobbiyst I would not be too concerned as I will have no finanical investemnt.
