I have downloaded the Nester program, it fails after the input sections are completed and hit ok,
presume the installatiion is all ok,
I have attached the file, don;t have the Screencast software,
Error screen pasted,
Fusion 360
Failed:
Traceback (most recent call last):
File "C:/Users/Browny/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/NESTER.py", line 90, in notify
createJoint(select, plane[0])
File "C:/Users/Browny/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/NESTER.py", line 46, in createJoint
joints.add(jointInput)
File "C:/Users/Browny/AppData/Local/Autodesk/webdeploy/production/9dc57ac7328faaa98e6bb4734628b2fbd5d10ece/Api/Python/packages\adsk\fusion.py", line 12413, in add
return _fusion.Joints_add(self, *args)
RuntimeError: 2 : InternalValidationError : request->setJointOrigins(jo1Def0, jo1Def1)
Ok
I have tried 1, 2 and all the plates, in both x and then y directions, simlar results.
Fairly new to Fusion, but ok with CNC, scripting - no idea.
