Message 1 of 16
issue with 3d parallel on sinumerik 808D vmc
- Mute
- Permalink
- Report
Hi everyone,
I couldn't find similar subject in other threads, so here it is:
I have problem with 3d parallel strategy when milling cavities with ball mills. In simulation everything is ok, but in actual milling it goes as shown on attached image. it plunges into the wall instead of following programmed toolpath.
I use sinumerik 808D control, but 840D post, because.. well.. it worked just fine till this part.
cps file and generated mpf in attachment.
In siemens control tool is set as ball mill but I suppose it doesn't matter in case when I use cam.
I would be grateful for any suggestions.
Piotr.
