- Mute
- Permalink
- Report
So, this is a new one for me. Model I'm working on, need to start off by poking a few mounting holes in the bottom. Flip the model over and go to work. Make my setup, choose the face that will be "Z" and the edge that will be "X", flip the X axis, hit OK. Choose Drill, select my tool, define the speeds, choose the faces, select the drill cycle. Click OK, greeted with an error. Double clicking on the red exclamation point tells me: The face is opposite tools orientation.
Odd....so I try using Tool Orientation, error persists.
I've restarted Fusion, and the error is still there.
I can do a Bore cycle as well as a Profile, so it seems to be related to the drilling dialog. Or something....
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
