BUG in 2D trace (new?)
fritter63
Message 1 of 12
fritter63
Video shows it all. All of a sudden after the update(s) 2D trace doesn't seem to be working for me:
Replies (11)
Message 2 of 12
LibertyMachine
Hmm. I'm seeing that too, if I use the Project to Surface option. However, I think I may have a workflow that will get you what you need, if you are doing straight lines.....: Sketch, extrude it out. Project a plane above the part (arched area) Draw a line on it. Create plane at 90 degrees to arched face. Use that to slice the face, creating a line across the part. CAM, make the setup and proceed as normal. No issues that way. However, if you have actual contours, I'm not sure what that work-around would be.
I think you should file a bug report. You already have the screencast made, so it's a quick enough email to send out.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 12
fritter63
Any update on fixing this issue?
Message 4 of 12
LibertyMachine
Did you submit a bug report, and if so, did they give you a case number?
Seth Madore
Message 5 of 12
fritter63
yes.
Message 6 of 12
Mike.Grau
Hi @LibertyMachine,
Thank you for sharing this screencast with us.
I did a couple test and this gave me a hint what could have caused what we have seen in the screencast.
It might depend in the way how your construction line has been projected to the surface.
Could you may test the following:
1. MODEL: Could you scroll back in your time line right after you have created the sketch
2. MODEL: Redefine the origin plane of the sketch and select the origin X-Y plane that the origin sketch is beneath the conic surface
3. MODEL: Re-project the sketch to the surface
4. CAM: Edit the Trace and re-select the "Curve Selection"
5. CAM: Start the simulation with the same settings
It would be great if you could share your file with us.
You can send me a private message to mike.grau@autodesk.com
Please, keep us updated if this helped.
Message 7 of 12
fritter63
@Mike.Grau
no, that did not help. Model file attached.
Message 8 of 12
HughesTooling
@fritter63 Here's a workaround, see screencast. For some reason the curve is selected as a closed curve, don't know why I  drew another arc and had the same problem. You need to unselect the curve in the op then reselect and click on the blue path and change to open curve.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 12
fritter63
@HughesTooling
Mark to the rescue (as usual)!
That did it, thx.
This is still a bug I think?
Message 10 of 12
HughesTooling
Yes I'd say it's a bug, how can a single arc segment be closed. I redrew just in case it was a problem with projecting and still got the same problem. File attached with second arc. What made me suspicious was you can select the curved edge of the body and it machines the full edge.
Mark
Mark Hughes
Message 11 of 12
@HughesTooling @fritter63
I too use the trace tool quite a bit for clearing cavities where a regular form cutter will not go. I too noticed this bug. However, selecting the curve using "ALT" pressed will not give you a closed curve and all should work well. If you don't do that, even changing the path direction by clicking the arrow does not work.
Hope this helps.
Naresh
Message 12 of 12
Mike.Grau
Hi @fritter63,
Thank you again for sharing your design. This was really helpful
And thank you to @HughesTooling for sharing the work around with us.
I have shared this information with the Fusion 360 CAM team and they will work on this issue.
