Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
ATTN users using Cloud libraries - Hot fix coming.
al.whatmough
Alumni Alumni
Message 1 of 27
al.whatmough
We have found an important issue and would like to get a warning out quickly to help avoid loss of data with your cloud tool libraries.
The team is working hard to correct the issue in a hotfix. This does affect Cloud libraries on both the mac and PC side.
Putting the importance of your tool libraries first, wee recommend in the short term to export your cloud libraries and then import them to a local folder.
The team takes this issue very seriously and will update here with more information on timing for the hotfix.
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Replies (26)
Message 2 of 27
juanaviles
I just noticed this today after my latest update.  My Cloud Library is gone.  Will we be getting these libraries back or are they gone forever?
Message 3 of 27
HughesTooling
This link should take you to A360 Drive trash folder, from there you should be able to restore your files. You might want to look in the CAMTools folder under all datafirst!
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 27
juanaviles
Thanks for the reply Mark.
That link doesn't work for me, and I don't really understand what you mean by, "CAMTools folder under all datafirst".  I'll just wait until the hotfix is implemented and see if they return.  If not, I'll just start over and make sure I do regular backups before upgrading again.
Message 5 of 27
HughesTooling
Try going to your Dashboard and selecting A360 Drive top right of your screen and see if that works.
That should take you here. Your tools should be in the CAMTools folder if it's empty try looking in the trash, if the files are in the CAMTools folder you can download from there and save backups.
Mark
Mark Hughes
Message 6 of 27
al.whatmough
@HughesTooling
Thank you for jumping in and helping out while we work to fix things on our end.
If you where not allready an  "experte elite" I woudl be nominating you now!
The team tells me they have sourced the issue and and should have a hot fix for it this week.
Al
AL Whatmough
Message 7 of 27
juanaviles
My dashboard looks very different than what you posted, and the link you posted to it just brings up a blank page. I'm guessing A360 is different from Fusion 360?
Message 8 of 27
HughesTooling
Have you ever looked at any of your project in your internet browser? If you click your name in the data panel it should open A360 in your browser.
Mark
Mark Hughes
Message 9 of 27
I can confirm that my cloud library is also gone. It was not located in the trash (which is called "archived" for me) either. I'd be interested to know if the library will be restored? My last archieve is from a few months ago...
Message 10 of 27
HughesTooling
Archived is in A360 not A360 Drive.
Select A360 drive from the top right in your browser.
Mark
Mark Hughes
Message 11 of 27
juanaviles
Clicking my name there also brings up a blank page 😞
Lukily the Cloud Library I started, was for the current project I'm working on, so all the tools are still in my CAM Tool Library under "Documents".  Until the cloud library issue is resolved, I can use the tools from there.
Message 12 of 27
I don't seem to have the same options as you when I try and access A360 Drive. It just brings me back to A360 every time.
Message 13 of 27
HughesTooling
Sorry I forgot you need to enable viewing A360 drive, click your initials and click settings then enable.
Mark
Mark Hughes
Message 14 of 27
Thank you very much! That did the trick for me.
Cheers,
Adam
Message 15 of 27
AmishSolanki
Ahh, so this is where my tools went Smiley Sad
SS CADCAM - www.sscadcam.com
@sscadcam
Message 16 of 27
al.whatmough
Quick update - There is a HOTFIX scheduled for tonight.
This will roll back the .tools format to .Json
AL Whatmough
Message 17 of 27
Al,
Thanks for the heads up.
I was able to drag my tools from my cloud library to my local library without incident.
After using the Export Library feature all of my tools that I exported were deleted when I went back in!!
I was able to re-import the tools using the "Import Library" function in the CAM Tool Library, but this was disconcerting all the same.
Message 18 of 27
Is there a fix for this yet? Still not seeing my library in the cloud.
Message 19 of 27
balsmen
Hi Jason,
Yes a fix for this problem was released on Thursday 5/12. Have you updated to the new version of Fusion? If you go to the '?' in the top right corner, and then click about you should see 2.0.2016.
We weren't able to do an auto-migration of your library, so you would have to import the library again.
Have you gone to your trash in A360 Drive and attempted to find the tool library prior to this problem (the one with extension JSON, NOT TOOLS)?
Once you find that library, you should restore it, download it locally to your machine and then use the import button in the Fusion Tool Library Manager.
I would be glad to walk you through these steps via skype if you are still having problems.
Feel free to reach out to me directly at [email protected]
Best Regards,
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
Message 20 of 27
AmishSolanki
Awesome! Thank you Noah!!! Was able to get my library back from the trash which is a huge time saver! Cheers again!!
@sscadcam
