Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Issue with Presenter
0 REPLIES 0
Message 1 of 1
sawant_vinod
293 Views, 0 Replies
Dear All,
I am facing problem with presener options in NAviswork manage 2014
I have following below mentioned steps for presenter
  1. Go to the Materials tab of the Presenter window.
  2. Right-click in the right side pane of materials tab and select Load Palette
  3. In the Open dialog box, navigate to the and select the required "***.nwp" file, then click Open
  4. Drag and drop the White tile material on floor object of the model.
  5. Go to the Rules tab. Check the check box to Map Presenter materials to Selection Sets by name. Clear the check box for Apply to current selection only, and then click Apply.
  6. Go to the Effects tab. Expand Recommended à Backgrounds archive and drag the Environment background into the right side pane.
  7. Expand Recommended à Environments à Panorama archive and drag Sky into the right side pane
  8. Go to the Lighting tab. Expand the recommended archive and drag the Environment light studio into the right side pane.
  9. Double-click the Environment light and change the Intensity value to 2.
  10. Click Render at the bottom of the Presenter window, to start the rendering process in the Scene View. Click Clear to clear the render in the Scene View.
But I am not getting desired model view with Sky effect..
Please guide how to achieve this effect.
Vinod
0 REPLIES 0
Rail Community
