Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
uv layout overlapping issue?
3 REPLIES 3
mianmms
1254 Views, 3 Replies
Hello All,
I am New to mudbox, I have an issue with my model let me explain it.
I have a model with 4 objects(Body, Face & eyes). I have unwraped them in Maya & arranged uv layout as i needed ( I need texture of body & face in saperate files).
Problem is that when i am painting on body its also apears on face & same issue for face. means when i am painting on one object it apears on other objects. seams like it is an issue with uv layouts(its overlapping) but i need same layout. Is there any option to paint on single object in a scene?
3 REPLIES 3
mianmms
in reply to: mianmms
here is an image.
RobinBall6995
Yeah this is because all the objects are using the same material. Assign a different material to each and you can paint individually. Right click>Assign Material.
mianmms
in reply to: RobinBall6995
Thank you for you time Robin. problem is solved.
