Community Support,
I just downloaded the Mudbox 2009 Trial. I get the following message any time I try to manipulate an object in any way including the objects you choose during startup such as sphere etc.. It doesn’t matter whether I try to move or reshape the object, as soon as I make a change, I get this error message:
“An unknown error has occurred while performing the operation. We are sorry for the inconvenience.”
The program doesn’t entirely lockup since it let’s me exit by hitting the window close X and I still have access to menus. But I can no longer do anything in the program and I have to close it. It also does not lock up my computer in any way.
This doesn’t feel like a driver issue to me. It apeears to have something to do with User account access since I think it is creating the error when the program trys to store image data/log info onto C:/User..... I am the only user and I have admin priveledges.
I am running:
Vista 32 bit Home Premium
Alienware M15x Laptop
Geforce 8800M GTX Forceware ver. 175.80
Directx ver 10
I uninstalled the trial, de-activated UAC, rebooted but upon the second install, the program did not ask me for a default path for data storage. I found this odd and I received the same error. I also tried changing the save paths in preferences while in the program but regardless of changes I make to the data path, it always reverts back to a C:\User..... path.
I discovered that even with uninstallation, the C:\User folders for Autodesk are still there. So I deleted them manually and tried another install. This time it again asked for a path to store data. I directed it to C:\Autodesk\data hoping to avoid the C:\User directories. Again I had the same error. And upon checking preferences, paths I find that Mudbox is still trying to save data in C:\User....
I really do think this is a User access issue. Very strange since I have numerous other applications with no problems.
I would really love to try out this software.
Just for fun I installed the trial on my 5 year old Dell Inspiron 9300 laptop and it runs ok. This is also why I am convinced this is some wierd User account access issue in Vista. For the record, Photoshop CS3 and ZBrush3 work fine on my Vista system.
Thanks for any help
Allan
