Show only
Search instead for
send to mudbox in 2013 doesnt keep smoothing groups
no I haven't but if you export normally using fbx it is using the 2013 version, so I assume the latest version ships with the new Max 2013. Plus as I mentioned it works if you export/import normally. It only fails if you use the "Send to" feature
I had the same problem, but when i scaled my object down (box, 1 x 1 x 1 meter + turbosmooth - edit poly) and send that to mudbox, everything "seems" to work fine
