hi everybody
I need help, I Mudbox 2013 all ok the installation, but I can not start because there is an error that prevents me:
"An unknown error has occurred while performing the operation.
We are sorry for the inconvenience."
here's a picture: http://tinypic.com/r/2v9q25s/5
i have acer aspire 5755g
intel core i7-2630QM 2GHz
with turbo boost up to 2.9GHz
NVIDIA GeForce GT 540M
6GB Memory DDR3
use windows 7 64 bit
I hope you help me
Solved by max_monette. Go to Solution.
I solved it in an other way. The reason was the driver of my graphic card (320.49 Gtx 760), I installed the next one (a beta) and now everything work fine.
In some cases, the problem may be incorrect indications paths to system folders Mudbox (Windows-> Preferences-> Paths). For example, if part of the path will have Cyrillic: [E 😕 User / Иван / Autodesk / Mudbox 2015/data] - Mudbox can produce the type of error:
"An unknown error has occurred while performing the operation. We are sorry for the inconvenience."
Try changing path that the words had only Latin. Hopefully helps. Good luck.)).
