Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
height map for a terrain?
3 REPLIES 3
1984 Views, 3 Replies
Hi - I'm somewhat new to Mudbox so I appologize is this is a simple question. I'm trying to use Mudbox as a way of "sculpting" a landscape. Nothing out of control, but some basic shape generations - slopes, terraces, driveways, etc. I would like to start my model with a height map I built for an earlier project. Is there a way to create a plane in mudbox and then using a greyscale heightmap, set the low and high elevations (for example black is 0' and white is maybe 100')? I've googled around and found that you can add a height map to add shape and definition, but haven't found a way to make it drive the entire shape. Then to be able to determine the high and low elevations is a whole different story - i can't find much on that at all.
Any thoughts?
3 REPLIES 3
Wondering this also.
Going to Sculpt > Sculpt using maps KINDA works...
RobinBall6995
In what way Kinda? That's what that feature does. Displaces the mesh based on a texture mapped to the existing Uvs. You need enough resolution in the plane. You can set the multiplier in the Advanced rollout to make it more or less intense or just set the strength of the new layer it makes after.
in reply to: RobinBall6995
Kinda in the sense that it seems the way mudbox reads the contrast of the values of neighboring pixels and how it changes the mesh based on that just seems to be very different compared to how many other pograms I have been using does it.
