I imported a plane from 3dsmax 2012/64 into MudBox 2012/64. The UVs at Level 0 and Level 1 and Level 2 are fine. Exactly where they should be located. But when I move up to Level 3 and up to Level 8.
The UVs get weird. one strip along one side will not correctly display. ???
Also at level I get an error message " Failed to load texture Files Both c:/users/blahblah/Terrain_Color_Diffuse_u1_v2.tga and c:/users/blahblah/Terrain_Color_Diffuse_u1_v2.tga
Level 0 All is Correct
Level 1 Still Correct
Level 2 Correct Again
Level 3 Here's where things go wacky
I know I am a noob with MB but would anyone know a solution to this problem?
