MudBox 2015:
Complete "Edited Curve" around a cylander:
Corresponding Mirrored Curve on the "X-Axis":
After creating a multiple edit curve with the mirror function on in "X" the mirrored curve is incomplete and corrupt.
If it is a single line segment the function acts normally. However in drawing a curve around a cylander (which is impossible with a single stroke) results in a corrupted curve. When right-clicking "stroke on curve" the mirrored stroke is mucked.
Results below:
Would be a "Good to have" fix for a future, hopefully very soon update.
I've been searching for an answer to this for 5 mins and I found this exact complaint back in 2012, it's 2022. Why isn't this fixed? What's the deal Mudbox?
to get around it. with the Curve loop tool selected> drag out a line across the arm with mirror turned on> you'll have a cleaner curve
