This questions regards Mudbox 2015 / 2014.
I added a stamp on another computer that had Mudbox 2014, and when I went to open the Mudbox file on my machine running Mudbox 2015 the painted stamp was missing.
Obviously the stamp needed to be added to that machine as well.
I added the same stamps to the 2015 but still the paint layer did not appear when I opened the .mud.
What is the trick to adding stamps and painting on one machine and then being able to open up that Mudbox file on a different machine, and re adding the stamps?
Solved by tony.su. Go to Solution.
I don't think the layer missing was due to stamps.
Did you copy the texture folder at same time?
