Community Feedback
Valued Mentor
2 Kudos
Post 1 of 5
Turn off smileys?
409 Views, 4 Replies
06-27-2010 02:18 PM
Is there any way to turn off smileys?
It's a problem for those posting code, like for example:
       (defun C:smileytongue:ROOF () ...)
The colon + P has become a smiley.
Better yet, some reasonable degree of intellegence in
the processing of message bodies could've probably
eliminated most of the unintended smileys.
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
34 Kudos
Post 2 of 5
Re: Turn off smileys?
06-27-2010 07:23 PM in reply to: caddzone
See here.
Steve Johnson - blog nauseam - ClassicArray
Valued Mentor
2 Kudos
Post 3 of 5
06-29-2010 07:16 PM in reply to: Steve_Johnson
I understand that they can be turned off by each user, but what I was
getting at was unintended smileys that would not become those regardless
of what a user's settings are.
for example
 (defun C:PROOF () ...)
The unintended smileys even show up when you insert code
Valued Mentor
22 Kudos
Post 4 of 5
06-29-2010 07:44 PM in reply to: caddzone
Tony,
I've just turned emoticons OFF
:smileytongue:
so there  to the software
:smileyhappy:
at least code isn't rude to me ( much) any longer.
for example
p.s.
'they' still need to fix this one
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
34 Kudos
Post 5 of 5
06-29-2010 07:49 PM in reply to: caddzone
Yes, I fully agree, it's not good enough. That was discussed in that thread too.
