Community Feedback
Valued Mentor
TrevN
Message 1 of 15 (1,498 Views)
The New Board, Hmmm
1498 Views, 14 Replies
06-07-2010 03:06 AM
First impressions of the new forum, hmmm not overly impressed!
And how do you set your Author name back to how it was? Mine has changed!
Here I am :smileyhappy:  The name displayed on the left is your login/userID.  You can change this to any supported value under Edit Account Settings.  Unfortunately, the userID does not support spaces.
If you were using a NNTP before the new system was launched, older posts will display whatever "handle" you had configured in your newsreader client. Through NNTP, users were "anonymous" behind the scenes (no authentication).   We could only capture and preserve your newsreader name on the post, but could not tie back to an Autodesk Sign in account.
pendean
Message 2 of 15 (1,483 Views)
Re: The New Board, Hmmm
06-07-2010 05:43 AM in reply to: TrevN
My Settings link, upper right side. Explore.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
TrevN
Message 3 of 15 (1,476 Views)
06-07-2010 06:04 AM in reply to: pendean
Ahh yes, did all that, It's even got the correct name in there, but my name against post is still incorrect!
pendean
Message 4 of 15 (1,466 Views)
06-07-2010 06:20 AM in reply to: TrevN
To the left of each post? Not a user option to edit, never has been since way before the last change/ old system. Contact Eric Wright with Autodesk, the guy posting about the forums changes, he might be able to help.
Valued Mentor
TrevN
Message 5 of 15 (1,463 Views)
06-07-2010 06:24 AM in reply to: pendean
Yes, the name on the left.
This has changed from before the update, it should not read tnorman, it should, as it has always done read Trev N.
And yes, the last time they updated this forum, my name again changed but was easily put back, now I haven't a clue, hence I'm asking!
pendean
Message 6 of 15 (1,437 Views)
06-07-2010 07:10 AM in reply to: TrevN
Find Eric Wright's email address and contact him for help, if it can be done that's the one person to do it. Then share with the group your findings of course, I'm sure you are not the only one.
WorkerBeeatDDP
Message 7 of 15 (1,425 Views)
06-07-2010 07:24 AM in reply to: TrevN
the name on the left is the one you used to create a login ID IIRC
Dave - DDP
Acad 2012 and Revit 2012
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
Valued Mentor
TrevN
Message 8 of 15 (1,419 Views)
06-07-2010 07:27 AM in reply to: TrevN
That may be so, but it's not the one I have used for the past few years as an identification on the forums.
Last week it was as I wanted it, since the update of the site it has changed.
Moderator
Discussion_Admin
Message 9 of 15 (1,387 Views)
06-07-2010 08:07 AM in reply to: TrevN
Trev,
You can change your login with the "EDIT ACCOUNT INFORMATION" link at the top right of any page just make the adjustments you want then enter your password and click "submit" at the bottom.
You will have to log out and back in with your new logon for this to take affect.
Discussion_Admin
Valued Mentor
TrevN
Message 10 of 15 (1,365 Views)
06-07-2010 08:26 AM in reply to: Discussion_Admin
No, that didn't work either!
