Community Feedback
Community Feedback
1,701 Kudos
Post 1 of 9
smiley faces in Code inserts
2451 Views, 8 Replies
06-19-2012 11:29 AM
Is there a way to prevent the inclusion of smileys in a code insert box?
I want this:
But get this:
'cut a column
excelApp.Columns("G:G").Cut
'insert the cut column
excelApp.Range("D1").Insert
'adjust column width
excelApp.Columns("D:D").AutoFit
'reset selected cell to A1
excelApp.Cells(1,1).Select
'suppress prompts (such as the compatibility checker)
excelApp.DisplayAlerts = false
'save the workbook
wb.Save
 Thank You,
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Fixed, there was a setting that was released not too long ago we weren't aware of.  As long as you use the "Insert Code" button you should be all set, see your OP, smiley is gone :smileywink:
29 Kudos
Post 2 of 9
Re: smiley faces in Code inserts
06-20-2012 06:06 AM in reply to: Curtis_Waguespack
Great question, and I'm actually not sure. Would be wonderful if we could turn the smilies off in certain boards that tend to have more programming scripts in them.
Let me find out what we can do, and I'll get back to you.
Thanks!
Jillian Bejtlich
Forum Community Manager
Moderator
51 Kudos
Post 3 of 9
06-20-2012 08:03 AM in reply to: Curtis_Waguespack
 There are a couple of threads in this forum on the topic and I believe it's still a individual user display preference unless there has been an update that Jillian finds for us.
Until then it is explained how to disable viewing them in this thread.
Discussion_Admin
34 Kudos
Post 4 of 9
06-26-2012 11:11 PM in reply to: Jillian.Bejtlich
This is one of the many things that have been complained about since the very beginning of the Lithium disaster. Eric pointed out the per-user turn-smileys-off thing fairly early on, here:
http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/How-to-prevent-smileys-from-displaying-espe...
As we pointed out at the time, that's not a proper solution. Code should always display unformatted, period. It's not complicated. The fact that Lithium still hasn't fixed this problem 24 months later tells me that it never was, and most likely never will be, a suitable platform for technical discussion groups like these.
Steve Johnson - blog nauseam - ClassicArray
Employee
25 Kudos
Post 5 of 9
06-27-2012 12:43 PM in reply to: Curtis_Waguespack
Brian Kling
Sr International Customer Experience Lead
34 Kudos
Post 6 of 9
06-27-2012 10:35 PM in reply to: brian.kling
29 Kudos
Post 7 of 9
06-28-2012 06:01 AM in reply to: Steve_Johnson
Hmmm... thinking I ought to go put a sticky post up in the more programming centric boards about this new functionality, huh?
Glad we were able to help!
Jillian Bejtlich
1,701 Kudos
Post 8 of 9
06-29-2012 02:39 PM in reply to: brian.kling
If "D:D" <> "D:D" Then
MessageBox.Show("No kudos for You!", "Autodesk Forums")
Else If "D:D" = "D:D"
MessageBox.Show("Thanks! :D", "Autodesk Forums")
End If
1,701 Kudos
Post 9 of 9
06-29-2012 02:41 PM in reply to: Jillian.Bejtlich
A sticky probably isn't needed, since it's now working as expected without the need to do anything special.
