Community Feedback
AllenJessup
Message 1 of 10 (534 Views)
Search Board / community
534 Views, 9 Replies
11-20-2013 11:49 AM
I've found that if I'm in a forum and I use the search field in the upper right to search a board. On the results page the text in the search field is maintained. But Board changes to Community.
The text in the search field also is transferred to the field directly above show. If you want to edit the search by a word or correct some spelling. Your natural inclination might be to edit it in that field and hit search next to it. Unfortunately you then end up searching the whole Community and getting results from many products you're not using.
Not a huge deal. But something to consider for change in the future to stave off user frustration when confronted with a wasted search.
Allen
nestly2
Message 2 of 10 (525 Views)
Re: Search Board / community
11-20-2013 12:59 PM in reply to: AllenJessup
I believe it does that because the 2nd field in the upper right search area (location) automatically detects what area/forum you are in and filters the results accordingly.  It wouldn't really make sense to search the search page, so defaulting to "Community" when on the main search page seems logical enough to me.
I'm curious about what your preference would be?  Perhaps remember which area/forum the search was originally initiated from?
AllenJessup
Message 3 of 10 (519 Views)
11-20-2013 01:20 PM in reply to: nestly2
I'd think it should maintain the board that I originally searched from. The most likely reason to initiate a search from the search results page is to refine or correct the search in progress. It wouldn't make sense that once I've gotten results from the Civil 3D forum that I'd suddenly want to correct a word and then search the whole community. That just gets a ton of results that don't pertain to Civil 3D.
But I can't go back or change it back to Board or Civil 3D. So if I want to correct or refine the search. I have to go back to the Civil 3D board and start over.
Allen
nestly2
Message 4 of 10 (508 Views)
11-20-2013 02:27 PM in reply to: AllenJessup
You should not have to go back to the original forum to refine the search, you should be able to refine the search string, search location, or any of the other filters right from the main search page without losing any of the existing search criteria.
If you're trying to refine the search from the upper right search box again, then yeah, that doesn't work because that location defaults to the current page, not the original page.  I don't think it would be possible to code it to do both.
See if this screencast helps
 http://www.screencast.com/t/yeosQO1A1s
AllenJessup
Message 5 of 10 (482 Views)
11-21-2013 05:09 AM in reply to: nestly2
OK. I can't hit screecast.com from work. But I went back and tried it again this morning and it worked as it should. I don't know if I was doing something wrong or if there was a temporary glitch in the new site. After I'd experienced the problem during an actual search. I had tested it again and got the whole community result again. All well now though.
Thanks.
Allen
nestly2
Message 6 of 10 (472 Views)
11-21-2013 05:45 AM in reply to: AllenJessup
I don't know if this applies in your case, but it appears to be script (javascript) dependant.  If I disable javascript for the site ADSK is using for analytics, I too get kicked back to "Community" as the search location when attempting to refine the search.  Maybe the script wasn't running due to maintainence when you tried previously?
One other thing I did notice in your screenshot, and my testing as well is that the search box width "shrinks" after the 2nd search, making it difficult to change the search criteria.  Happens with both IE and FireFox
AllenJessup
Message 7 of 10 (464 Views)
11-21-2013 06:04 AM in reply to: nestly2
OK. I'll take that as an excuse. No way to know at this point.
Allen
philip.s
Message 8 of 10 (410 Views)
12-17-2013 03:58 PM in reply to: AllenJessup
This one should be fixed now / with a previous update. Can you confirm?
Philip Schmelzer
nestly2
Message 9 of 10 (403 Views)
12-17-2013 05:44 PM in reply to: philip.s
I believe the initial issue with the search location may have been a temporary/script issue, but the problem with the shrinking search box remains  (FF 25.0)
philip.s
Message 10 of 10 (388 Views)
12-18-2013 10:46 AM in reply to: nestly2
Thanks for confirming / looking into it now!
Philip Schmelzer
