Community Feedback
Community Feedback
Valued Mentor
KerryBrown
Message 1 of 8 (521 Views)
Post Editor related Issued
521 Views, 7 Replies
06-11-2010 06:30 PM
I notice that when quoting a post the cursor is located UNDER the quoted text.
I think that most here prefer 'top posting' ie having the quoted text at the bottom of the post.
1)  Is it possible to have the 'Message Post Editor' configurable for individual users.
2)  I want the Editor TextSize to honor the Display text settings. I see no point in having "Large" set for  Display size in my settings and having the FontSize in the Editor display in a size I can't read.
   On the issue of Font Size, I expect that if I have the font size set the editor will honor it during the post, at least untill I change it again ... that's not happening.
3)  If I place a blank line in the editor when composing a post I expect the preview and post mechanism to honor my intent ... that's not happening.
4) I don't appreciate emoticons in my code, but an occasional :smileyhappy: in a post may relieve the tension. Please fix this.
5) [added] What's the point in having a "Preview" option for a post If it doesn't preview the post as it will be posted. The post window is half as wide again as the preview window. Please fix this.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Valued Mentor
KerryBrown
Message 2 of 8 (496 Views)
Re: Post Editor related Issued
06-17-2010 03:20 AM in reply to: KerryBrown
BUMP !!
*Expert Elite*
pendean
Message 3 of 8 (494 Views)
06-17-2010 05:33 AM in reply to: KerryBrown
#4 is discussed about a dozen posts below yours from WRIGHTE, explore it:
http://forums.autodesk.com/t5/Questions-Feedback-about-the/How-to-prevent-smileys-from-displaying-es...
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
KerryBrown
Message 4 of 8 (479 Views)
06-17-2010 03:14 PM in reply to: pendean
Dean,
I almost accepted your post as a solution
.. but what about the other items  :smileyhappy:
Steve_Johnson
Message 5 of 8 (473 Views)
06-17-2010 06:45 PM in reply to: KerryBrown
#4 is discussed in that thread, but not resolved. Kerry's point is still 100% valid as stated.
Steve Johnson - blog nauseam - ClassicArray
Employee
wrighte
Message 6 of 8 (454 Views)
06-18-2010 03:42 PM in reply to: KerryBrown
You can add the quote anytwhere in the post.  Clicking "Quote" adds the quoteback text wherever your curser is at that time.
The post editor is not a configurable item.
Not clear what you mean on #3
I've addressed #4 (and have noted Steve's thoughts on the subject)
Agree, preview is not exactly the same because of the wider display of a posted topic.  I don't see any discrepancies beyond auto-line wrapping (still preserves line breaks). From a formatting perspective, where else are you seeing this as problematic?
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
Autodesk, Inc.
Valued Mentor
KerryBrown
Message 7 of 8 (448 Views)
06-18-2010 03:57 PM in reply to: wrighte
Agree, preview is not exactly the same because of the wider display of a posted topic.  I don't see any discrepancies beyond line wrapping. From a formatting perspective, where else are you seeing this as problematic?
This is a line, followed by an empty line...
this is another line, which should demonstrate item #3 .. then another empty line.
re #4: yes I mean primarily the line wrapping discrepancy.
... looks like the #3 issue has been fixed, sneaky.
Valued Mentor
KerryBrown
Message 8 of 8 (438 Views)
06-18-2010 04:10 PM in reply to: wrighte
Actually the blank line issue isn't resolved.
It seems to be a problem when Font size is changed,
The attached illustrates :
during preview 2 blank lines reduced to one.
return to editor,
all blank lines removed.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
