Community Feedback
Community Feedback
New Member
moharch
Message 1 of 3 (478 Views)
Imported image not showing/activating in 3ds max design 2013
478 Views, 2 Replies
06-04-2012 04:16 PM
Can not get the imported image from revit (fbx file) to appear in 3dsmax design. The sceen does not show the views with the image there.  It work just once after loading upate and its back to the same.  This is a 2013 version from autodesk assistance program.  I was thinking mavbe the program was not loaded properly.  This is unlikley since I inputed the product key and serial number.  Appreciate somones help.
Michael
Valued Mentor
vector2
Message 2 of 3 (476 Views)
Re: Imported image not showing/activating in 3ds max design 2013
06-04-2012 05:24 PM in reply to: moharch
Revit 2013 can link directly into Max 2013, no need for fbx.
In Max, click on that big green button at the top left corner
and go down to the "Import" menu and select "Link Revit"
You don't even need Revit installed on that computer. Just
click on a Revit file icon and see how you will have access
to all the Revit views in that file. All that stuff comes up in
the Max 2013 "Manage Links" dialog. One thing that confused
me was that you have to click "Attach File". And then there is a
bunch of other "old school" AutoCAD kind of stuff with Max
that's not too hard to figure out if you are a Max person, I'm
not. Good luck.
Moderator
Discussion_Admin
Message 3 of 3 (471 Views)
06-04-2012 05:31 PM in reply to: moharch
You can find the 3DSMax fourms on the AREA
Discussion_Admin
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
