Community Feedback
Moderator
Alexander.Rivilis
Message 1 of 8 (1,872 Views)
Accepted Solution
Forum bug.
1872 Views, 7 Replies
05-04-2012 06:48 AM
I've try to search and found some links:
Then I clicked one of link and saw:
What does this mean? It is look like problem only with links ended with ".../page/N", when N = 2,3,4,5, etc.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Ok managed to repeated the error.
Try using the forum search box in the image below for searches it has better options
There are some how to videos in the FAQ forum about using search here
I'll escalate the other error.
Discussion_Admin
Moderator
Discussion_Admin
Message 2 of 8 (1,865 Views)
Re: Forum bug.
05-04-2012 07:01 AM in reply to: Alexander.Rivilis
Alexander
Where are you starting your search from?
Discussion_Admin
Moderator
Alexander.Rivilis
Message 3 of 8 (1,862 Views)
Re: Forum bug.
05-04-2012 07:06 AM in reply to: Discussion_Admin
Moderator
Discussion_Admin
Message 4 of 8 (1,858 Views)
Re: Forum bug.
05-04-2012 07:34 AM in reply to: Alexander.Rivilis
Discussion_Admin
Moderator
Alexander.Rivilis
Message 5 of 8 (1,855 Views)
Re: Forum bug.
05-04-2012 07:38 AM in reply to: Discussion_Admin
I know how to search forums. It was only bug report. :smileyhappy:
Moderator
Discussion_Admin
Message 6 of 8 (1,850 Views)
Re: Forum bug.
05-04-2012 07:45 AM in reply to: Alexander.Rivilis
Alexander,
Just put that in there for others who might come across the the thread that do not have your working knowledge of the forums :smileyhappy:
Discussion_Admin
Moderator
Alexander.Rivilis
Message 7 of 8 (1,843 Views)
Re: Forum bug.
05-04-2012 07:58 AM in reply to: Discussion_Admin
OK! I'll assume that this topic also will be a reminder of Tony Tanzillo, who did a lot for this forum to promote AutoCAD Customization, ObjectARX, Autolisp/VisualLisp, VBA,  .NET and so on.
Moderator
Alexander.Rivilis
Message 8 of 8 (728 Views)
Re: Forum bug.
01-16-2013 10:34 PM in reply to: Alexander.Rivilis
I would like to be reminded of this unpleasant error. For example this post has reference to: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Navigate-Viewports/td-p/3751182/page/...
Post to the Community
New Post
Need installation help?
