Community Feedback
Valued Mentor
TrevN
Message 1 of 6 (1,166 Views)
Changing Author Name
1166 Views, 5 Replies
06-07-2010 06:33 AM
I started this thread elsewhere, can anybody help?
http://forums.autodesk.com/t5/AutoCAD-2011/The-New-Board-Hmmm/td-p/2692629
Employee
wrighte
Message 2 of 6 (1,139 Views)
Re: Changing Author Name
06-07-2010 05:55 PM in reply to: TrevN
Copying my reply...
The name displayed on the left is your login/userID.  You can change this to any supported value under Edit Account Settings.  Unfortunately, the userID does not support spaces.
If you were using a NNTP before the new system was launched, older posts will display whatever "handle" you had configured in your newsreader client. Through NNTP, users were "anonymous" behind the scenes (no authentication).   We could only capture and preserve your newsreader name on the post, but could not tie back to an Autodesk Sign in account.
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
Autodesk, Inc.
Member
chrisstaker
Message 3 of 6 (605 Views)
07-24-2013 07:39 AM in reply to: wrighte
Enter DWGPROPS at the command line.
This will pull up the drawing properties; Under the Summary tab, you can change the Title, Subject, Author, Keywords, and Comments of any AutoCAD drawing you are working in.
*Expert Elite*
Charles_Shade
Message 4 of 6 (599 Views)
07-24-2013 07:43 AM in reply to: chrisstaker
Welcome to the Autodesk Forums!
The OP was looking to have his Login name in this Forum updated not the name on the drawing files.
Thanks for offering the input and taking the time to. The more voices here in these Forums the better.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
chrisstaker
Message 5 of 6 (590 Views)
07-24-2013 07:55 AM in reply to: TrevN
I recently came across the issue of just changing the author of a drawing; after numerous unsuccessful google searches, I posted the solution, which is very easy, to this thread to help anyone else that comes across this issue.
*Expert Elite*
Charles_Shade
Message 6 of 6 (581 Views)
07-24-2013 10:08 AM in reply to: chrisstaker
You can also add Custom Properties from that same Dialog and call these into the Titleblock or other boiler plate text strings using Fields in AutoCAD.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
