Community Feedback
Moderator
52 Kudos
Post 41 of 48
Re: Avatar
05-30-2012 10:53 AM in reply to: mel0526
Mélanie,
Just took a look at your profile everything seems to be ok from my end.
Below is a screen shot of where you can find the settings under My Settings.
Please attach a screen shot if you see something different.
Discussion_Admin
Active Member
0 Kudos
Post 42 of 48
Re: Avatar
05-30-2012 12:20 PM in reply to: Discussion_Admin
I added an attachment of my setting tabs.
Thanks.
Mélanie
Inventor 2012
Windows 7
Moderator
52 Kudos
Post 43 of 48
Re: Avatar
05-30-2012 12:29 PM in reply to: mel0526
Mélanie,
I have escalated this for investigation.
Someone will let you know when this is resolved.
Discussion_Admin
Employee
34 Kudos
Post 44 of 48
Re: Avatar
05-30-2012 03:04 PM in reply to: mel0526
Troubleshooting how it happened, but I have restored your avatar access/permissions.
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
Autodesk, Inc.
Active Contributor
2 Kudos
Post 45 of 48
Re: Avatar
12-15-2012 03:42 AM in reply to: wrighte
Hi Wrighte,
Can u also tell us how to choose a custom avatar? I'm only able to choose between the standard avatars. How can I choose to use an avatar I can upload?
Green check.png  Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful
Autodesk Inventor 2013 & 2014 Certified Professional
*Expert Elite*
920 Kudos
Post 46 of 48
Re: Avatar
12-15-2012 07:45 AM in reply to: L.van.Gorsel
From the Forum FAQ's, Personalizing your forum profile:
"Select an avatar image to display next to your user information.  Just navigate to the Avatar tab under My Settings.  Choose from the standard set of images we provide, or choose a custom avatar from your uploaded images (available to Contributor and higher levels mentioned above)."
Based on your post count you just recently moved to the Contributor level (due to you 15th post, I believe), so it should now be an available option for you.
Jeff_M, also a frequent Swamper
Active Contributor
2 Kudos
Post 47 of 48
Re: Avatar
12-15-2012 08:11 AM in reply to: Jeff_M
Thanks Jeff,
I realy don't know why I didn't look in the FAQ.. I should have done that.
Well I think I have to make a couple of posts the next comming days.
Regards.
*Expert Elite*
370 Kudos
Post 48 of 48
Re: Avatar
12-17-2012 05:21 AM in reply to: L.van.Gorsel
And the upploaded image will need to be approved before it will be allowed as an Avatar.
May take a day or so after uploading
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
