Community Feedback
Lineabove
Message 1 of 4 (229 Views)
Autodesk Building Design Suite
229 Views, 3 Replies
01-09-2013 02:01 AM
There is a discussion group for Autodesk Factory Design Suite and Autodesk Product Design Suite.
May I suggest a new discussion group: Autodesk Building Design Suite.
Lineabove
Message 2 of 4 (226 Views)
Re: Autodesk Building Design Suite
01-09-2013 02:11 AM in reply to: Lineabove
For example, as a first posting.
Currently use the Revit Architectural Suite and have been upgraded to the Building Design Suite.
When I install the Building Design Suite, will this modify my current installation or do I need to uninstall the Revit Architectural Suite and then install the Building Design Suite.
Valued Contributor
derrickmoore
Message 3 of 4 (216 Views)
01-09-2013 06:53 AM in reply to: Lineabove
It doesn't modify your current suite.
Charles_Shade
Message 4 of 4 (211 Views)
01-09-2013 07:28 AM in reply to: Lineabove
Typically all Autodesk product versions are freestanding full programs.
The S/N of the previous is needed for upgrade versions but the previous program typically does not need to be installed or modified.
There are rules as to how long you can keep the previous version that have to do with On or Off Subscription.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
