Community Feedback
Community Feedback
Member
0 Kudos
Post 1 of 4
access a reply to a question
313 Views, 3 Replies
06-08-2012 09:44 AM
How to i access the reply / answer to a question.
370 Kudos
Post 2 of 4
Re: access a reply to a question
06-08-2012 10:04 AM in reply to: agnesbt
In this Forum?
It should be on the right side of the post window in a gray box.
Or if it is an answer to your post you should receive an email notice and the post will be at the bottom (or top) of your thread depending on your preferences
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
997 Kudos
Post 3 of 4
06-08-2012 11:17 AM in reply to: agnesbt
Or by "access" do you mean edit?
If so, you can use the Options pull-down menu on the upper-right side of your post and select "Edit Reply".
You cannot edit anyone else's posts, and there is a limited time frame before you can no longer edit it.
Moderator
51 Kudos
Post 4 of 4
06-08-2012 11:24 AM in reply to: agnesbt
First welcome to our forums:smileyhappy:
You can find information on getting started in the forums including how to start and reply to a thread here
Here are a couple of other helpful links to get started
Ground rules
FAQ and how to forum
Hope these help
Discussion_Admin
