Community Feedback
Valued Contributor
amason43
Message 1 of 9 (575 Views)
Accept as Solution
575 Views, 8 Replies
06-18-2010 09:23 AM
We need to be allowed to accept more than one post as a solution.
Anthony Mason - CAD/BIM Manager
Nichols Melburg & Rossetto Architects + Engineers
Blog: Daily Occurrence
AutoCAD Architecture 2008 SP2 / Revit Architecture 2011
Microsoft Windows XP SP3 / Google Chrome
Employee
wrighte
Message 2 of 9 (566 Views)
Re: Accept as Solution
06-18-2010 02:58 PM in reply to: amason43
It's intended to be used to select the "best" contributing post to the solution.  One approach for a case where there is more than one would be to reply confirming what specifically helped and mark your reply as the accepted item.
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
*Pro
Jason.Piercey
Message 3 of 9 (548 Views)
06-21-2010 06:07 AM in reply to: wrighte
Which is likely to never happen with most posts.  I'm thinking the
majority of people will identify the first reply that works for them
as the "best" solution and never review the thread again.
Valued Contributor
amason43
Message 4 of 9 (535 Views)
06-21-2010 08:06 AM in reply to: Jason.Piercey
Especially since a lot of the things I've needed help with have involved multiple steps.  Example:
Hey, anyone know how I can 'abc'?
Yeah, try putting the 'L' in the 'c'.
Ok, I did that, and it mixed it up.
Oops.  That should be 'lowercase l' and 'uppercase C'.
Ohhh, nice, now I just really wish it would 'y'.
It will, if you 'x' the 't' and '.' the 'i'.
So, which one of these is the "best" solution?
Points for solving:
l=
C=
Distinguished Contributor
ACADuser
Message 5 of 9 (524 Views)
06-21-2010 10:52 AM in reply to: amason43
While I agree that there may be more than one post contributing to the solution.  Even if a post had a link to the supposed solution I would still read the entire thread.  A recent example that I ran across is in this post;
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Importing-LandXML-File-Scaling-Issue/m-p/2699071#M133...
Post #4 is relevant and may be part of the solution for someone else experiencing the problem.
I would rather have a good search engine rather than "solution" flags.  Maybe they should enable the "kudos" feature that way you know if the accepted "solution" was presented by someone having a good reputation - j/k.
ACADuser
Civil 3D 2015, Raster Design 2015
Windows 7 Enterprise
Dell Precision T5500 Workstation
Dual Quad Core Intel Xeon 2.53GHz Processors
24GB RAM, NVIDIA Quadro FX 4800 1.5GB
DUAL 27" Dell UltraSharp U2713HM
Valued Contributor
amason43
Message 6 of 9 (521 Views)
06-21-2010 10:55 AM in reply to: ACADuser
You may be kidding, but I don't think that's too bad of an idea.
Active Contributor
Ken.Krupa
Message 7 of 9 (465 Views)
06-28-2010 07:29 AM in reply to: wrighte
It would be good if the OP were able to change the "accepted solution" designation to another post - if a much better solution were later found and posted.
That happened to me, where a solution I accepted turned out to be half-baked, and I posted a better one myself. As is, anyone searching for the same problem will be lead straight to the half-baked solution and might never see the better one several posts further down.
Ken Krupa
Krupa CADD Solutions
http://www.krupacadd.com
Employee
matt.smith
Message 8 of 9 (460 Views)
06-28-2010 07:50 AM in reply to: Ken.Krupa
Ken,
You can do that.
1. Open the message you selected as the "accepted solution".
2. Click on the "Options" drop down and choose "Not the solution" and confirm it.
3. Accept a new message as the solution.
I just tried it out in the Test forums
Active Contributor
Ken.Krupa
Message 9 of 9 (457 Views)
06-28-2010 07:59 AM in reply to: matt.smith
matt.smith wrote:
Ken,
You can do that.
OK - Thank you!
Ken Krupa
