Classifieds
Classifieds
Member
ACCU-CAD
Message 1 of 16 (224 Views)
Wanted someone who can convert Micorstation to DWG format
224 Views, 15 Replies
05-24-2005 11:57 AM
My client has a future need for converting Microstation to dwg format. If you are able to do that I need a price quoted per file no clean up. E-mail sized you will receive a dgn and you will e-mail me the dwg 2005 or older. It is unknown what the release of Microstation file is.No spam please. If you can help e-mail me at accu-cadatvelocity.net or google accu-cad. It is assumed you know the @ for at substitution.
Thanks in advance.
*Biscuitnt
Message 2 of 16 (224 Views)
Re: Wanted someone who can convert Micorstation to DWG format
05-25-2005 05:04 AM in reply to: ACCU-CAD
You have mail!
Regards
David Graves
wrote in message news:4855015@discussion.autodesk.com...
Thanks in advance.
*AlmightySR
Message 3 of 16 (224 Views)
05-25-2005 05:46 AM in reply to: ACCU-CAD
http://www.cad-conversion.com/
Thanks in advance.
New Member
WANewhauser
Message 4 of 16 (224 Views)
05-25-2005 08:49 AM in reply to: ACCU-CAD
You will first need to know the MicroStation format (propably V8 or V7) because they are very different. If you or your client has a copy of MicroStation V8 it can do the translations singly or in batch.
HTH,
warren
*zer0
Message 5 of 16 (224 Views)
05-27-2005 03:00 PM in reply to: ACCU-CAD
i can help!
thecadalyst@hotmail.com
Thanks in advance.
Valued Contributor
kclevenger
Message 6 of 16 (224 Views)
06-03-2005 11:59 AM in reply to: ACCU-CAD
I may be able to help. I have been converting scanned drawings to AutoCAD for over 6 years now. If you can scan it in, I can convert it. All it takes is sending me the scanned dwg via e-mail, I can convert it to CAD then e-mail back to you. Let me know what you think.
Kathleen Clevenger
kclevenger@ameritech.net
New Member
uvantunano
Message 7 of 16 (224 Views)
08-10-2005 09:58 AM in reply to: ACCU-CAD
I think I can help you with the conversion from dgn to dwg.
If you e-mail me a dgn file to uvantunano@yahoo.com I will gladly try it for you. Of course the layer will be all named as numbers, and the drawing will need some work on matching line styles and text styles. But it would not hurt to try and see if I can help you. I'll need to know the AutoCAD version you are working on.
Cecilia
dclarkibi
Message 8 of 16 (224 Views)
08-19-2005 06:22 AM in reply to: ACCU-CAD
Maybe you already found a solution, and maybe I'm not understanding your situation correctly, but here is my suggestion. Use AutoCAD Map to convert the dgn to dwg. It's under the Map pull down menu -> tools -> import. From here you can set up a standard level to layer conversion based on the clients level names and your desired layer names, or you can have a straight conversion (level 1 = layer 1, level 2 = layer 2), etc.
This only takes about a few minutes per drawing. Hopefully you have not spent too much money on this so far.
Daniel Clark
Active Member
CADNEWYORK
Message 9 of 16 (224 Views)
06-17-2006 11:27 PM in reply to: ACCU-CAD
It should not cost too much and should not take too much time. But we would be able to give the estimate only after we get the drawings in hand. Some of the other services we provide are cad conversion, cad drafting, 3-d cad and rendering. We provide competitive quotes for cad services at some of the lowest prices you will find anywhere. Visit our site at http://www.new-york-document-scanning.com
Member
bryanrisk
Message 10 of 16 (224 Views)
09-04-2009 11:00 AM in reply to: ACCU-CAD
No doubt CAD conversion is very complex thing in architectural or mechanical design. Check this for cad conversions at reasonable price.
Here you can found almost all cad conversion services like scan to drafting, TIF to DOC conversion, DWG conversion, DWG to DNG conversion and raster images to vector images conversion. Edited by: bryanrisk on Sep 4, 2009 6:01 PM
