Community Classifieds
Shortcut Keyboard For AutoCAD
0 REPLIES 0
Message 1 of 1
507 Views, 0 Replies
Custom design your own perfect shortcut keyboard for AutoCAD:
The Martian Keyboard works beside your normal Earthling keyboard. You assign the shortcuts you need, and
color/label the keys into groups to give you the fastest and most efficient access to AutoCAD functions.
 The Martian Keyboard has the capability to hold all the AutoCAD shortcuts !
     -that's right, it can hold over 800 shortcuts.    It uses "Layer Keys" to shift to different layers of shortcuts.
It plugs into a spare USB port and does not require any software to operate.  Your programming is saved in the
keys, so you can unlpug it and take it home to work with your laptop.   Need a shortcut keyboard to work with
other software applications?  -then reload it with a new keyboard image you make.
Another great feature is to be able to program long text strings to a key that you use over and over, day after day.
Example, store a whole mailing address to a single key.
  - The Martian Keyboard can really streamline your AutoCAD workflow.
0 REPLIES 0
