If you are in the need of having multiple files of Microstation files converted to Autocad and need for the viewports in Autocad to match the views of the refrenced files in Microstation then you will want to have them done manually and accurately by using our services. We have provided these services to many Government contracted agencies as well as companies that work directly with the Military. You will not want to trust the translation of Nested references, Cells and Cell Libraries to be converted by automation or cheap services or software. What you will end up with is a mess that will have your subcontractors screaming and pointing the finger at you for any mistakes.
Contact me for a free quote or estimate for your file conversions
We are a US Veteran Owned Corporation located in the US
and serviced by veterans.
Florida Drafting Services
www.FloridaDraftingServices.com
Microstation to Autocad File Conversion Services
