Community Classifieds
Learn and write Visual Lisp object reactors with ReactorsWIZ v1.0
1 REPLY 1
188 Views, 1 Reply
Monday, August 04, 2003
ReactorsWIZ v1.0 By Caddximation Software
http://www.draftteam.com
Author: Luis Esquivel
New software to help you learn and write your own Visual Lisp object
reactors and make your own smart commands by following a code structure
with open source samples and using the reactorsWIZ.fas file that will handle
the object reactors internally.
ReactorsWIZ comes with two open source object reactors. The samples are
KeyNote.lsp and Detail.lsp commands including the reactors' structure
rwiz-keynote.lsp and rwiz-detail.lsp. Also, a companion set of many new
compiled Visual Lisp and Active-x functions very useful when you want to
write object reactors.
We need to know how many are interested in this software, please sign for a
full working copy of ReactorsWIZ here:
reactorsWIZ@draftteam.com
ReactorsWIZ still is under development 80% done and works now with multiple
objects, to handle reactors made with single objects we are still writing
the code.
ReactorsWIZ v1.0 will be available as evaluation software fully workable for
15 days, and can be use in one computer only.
This is your opportunity to learn and write "Visual Lisp Object Reactors"
and do not get worried on how to handle the object reactors, the program is
dedicated to Visual Lisp programmers, but if you do not know Visual
Lisp/Active-x just by following the samples provided you can learn that part
too. Registered users will be received also, open source samples of
commands with other types of Visual Lisp reactors.
Compatibility:
AutoCAD 2000i thru 2004 (+ vertical products)
Price:
Single - $60.00
Site license - $300.00
Note: The site license will require to register ReactorsWIZ on each
computer.
1 REPLY 1
Attention:
Base on the lack of interest on this project has been abandoned.
Best regards,
Luis Esquivel
