Community Classifieds
Keyboard for AutoCAD.
9 REPLIES 9
Message 1 of 10
JohnyShield
10630 Views, 9 Replies
Make an AutoCAD keyboard from an ordinary keyboard in two steps.
Installation
1.  Cut pictures with commands from the ReadMe file and attach them to your keyboard.
2.  Run Acad_Revolution.exe
Note. This app is for Windows based system and English version of AutoCAD. The default input language in Windows must be English.
How to Use
After the app is launched you have an additional keyboard mode where one button is one AutoCAD command. To switch between modes simply press Caps Lock button. You will notice that the letter H on the lower right corner of your screen will change to S. The letter H means Hotkey, the script is active; S means suspend, the script isn't working. When the AutoCAD window is not active all buttons work as normal, but don't forget to switch back before writing text in AutoCAD.
How Does It Work
The script is made in free program which is called Autohotkey. When you press, for example, the Q button the app sends "move" and then "enter". That is why, if you don't switch back before writing text in AutoCAD, you will type something like this
fillet
offset
matchprop
trim
 P.S.
I'm glad to answer to any questions and make changes on request.
Email: acadrevolution@gmail.com
Little donations are welcome. You could make them on PayPal using this link Donate.
9 REPLIES 9
Message 2 of 10
jimbowen
in reply to: JohnyShield
acad keyboards with shortcut keys have been on the market for 10 years. I've been using mine along with hundreds of other customers for years, they are great, much fast than a mouse, see link -
www.electronickeyboards.com/autocad-keyboards
Jim
Message 3 of 10
IvanShchitov
This app was transformed into an AutoCAD plugin. Many features, such as graphical interface for keys customization, were added. More information at:
http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Aonekeyshor...
Message 4 of 10
marec2009
I do not understant why you need this, I allmost for all commands use keyboard,
move: type: M and push space button
erase: type: E and push spce button
polyline: type:    PL and push space button
...... YOU HAVE all command in help
SPACE BUTTON = ENTER BUTTON
F1    Displays Help
F2    Toggles text window on/off
F3    Toggles OSNAP
F4    Toggles TABMODE
F5    Toggles ISOPLANE
F6    Toggles COORDS
F7    Toggles GRIDMODE
F8    Toggles ORTHO MODE
F9    Toggles SNAP MODE
F10    Toggles POLAR
F11    Toggles OTRACK
3A      3DARRAY
3DO   3DORBIT
3DW   3DWALK
3F       3DFACE
3M      3DMOVE
3P       3DPOLY
3R       3DROTATE
A         ARC
AC      BACTION
ADC    ADCENTER
AA      AREA
AL      ALIGN
3AL    3DALIGN
AP      APPLOAD
AR      ARRAY
-AR    -ARRAY
ATI     ATTIPEDIT
ATT    ATTDEF
-ATT -ATTDEF
ATE     ATTEDIT
-ATE   -ATTEDIT
ATTE   -ATTEDIT
B          BLOCK
-B       -BLOCK
BC       BCLOSE
BE       BEDIT
BH      HATCH
BO      BOUNDARY
-BO    -BOUNDARY
BR       BREAK
BS        BSAVE
BVS      BVSTATE
C          CIRCLE
CAM    CAMERA
CH       PROPERTIES
-CH     CHANGE
CHA    CHAMFER
CHK     CHECKSTANDARDS
CLI       COMMANDLINE
COL     COLOR
CO       COPY
CP        COPY
CT        CTABLESTYLE
CYL      CYLINDER
D          DIMSTYLE
DAL      DIMALIGNED
DAN      DIMANGULAR
DAR      DIMARC
JOG       DIMJOGGED
DBA      DIMBASELINE
DBC      DBCONNECT
DC        ADCENTER
DCE      DIMCENTER
DCO     DIMCONTINUE
DDA      DIMDISASSOCIATE
DDI        DIMDIAMETER
DED       DIMEDIT
DI           DIST
DIV         DIVIDE
DJL          DIMJOGLINE
DJO         DIMJOGGED
DL           DATALINK
DLI          DIMLINEAR
DLU        DATALINKUPDATE
DO          DONUT
DOR        DIMORDINATE
DOV        DIMOVERRIDE
DR           DRAWORDER
DRA        DIMRADIUS
DRE         DIMREASSOCIATE
DRM        DRAWINGRECOVERY
DS           DSETTINGS
DST         DIMSTYLE
DT           TEXT
DV           DVIEW
DX           DATAEXTRACTION
E              ERASE
ED            DDEDIT
EL             ELLIPSE
ER             EXTERNALREFERENCES
EX             EXTEND
EXIT          QUIT
EXP           EXPORT
EXT           EXTRUDE
F                FILLET
FI               FILTER
G              GROUP
-G            -GROUP
GD             GRADIENT
GR             DDGRIPS
H               HATCH
-H             -HATCH
HE             HATCHEDIT
HI              HIDE
I                 INSERT
-I                -INSERT
IAD            IMAGEADJUST
IAT             IMAGEATTACH
ICL             IMAGECLIP
IM               IMAGE
-IM             -IMAGE
IMP             IMPORT
IN               INTERSECT
INF             INTERFERE
IO               INSERTOBJ
J                  JOIN
L                LINE
LA             LAYER
-LA           -LAYER
LAS           LAYERSTATE
LE             QLEADER
LEN           LENGTHEN
LI               LIST
LO             -LAYOUT
LS              LIST
LT              LINETYPE
-LT           -LINETYPE
LTS            LTSCALE
LW             LWEIGHT
M               MOVE
MA            MATCHPROP
MAT          MATERIALS
ME             MEASURE
MI              MIRROR
ML             MLINE
MLA          MLEADERALIGN
MLC          MLEADERCOLLECT
MLD          MLEADER
MLE           MLEADEREDIT
MLS           MLEADERSTYLE
MO            PROPERTIES
MS             MSPACE
MSM          MARKUP
MT             MTEXT
MV             MVIEW
O               OFFSET
OP             OPTIONS
ORBIT        3DORBIT
OS              OSNAP
-OS            -OSNAP
P                 PAN
-P               -PAN
PA               PASTESPEC
PE                PEDIT
PL                PLINE
PO               POINT
POL             POLYGON
PR                PROPERTIES
PROPS         PROPERTIES
PRE              PREVIEW
PRINT          PLOT
PS                 PSPACE
PSOLID        POLYSOLID
PTW             PUBLISHTOWEB
PU                PURGE
-PU              -PURGE
PYR              PYRAMID
QC               QUICKCALC
QCUI            QUICKCUI
R                   REDRAW
RA                REDRAWALL
RC                RENDERCROP
RE                 REGEN
REA              REGENALL
REC              RECTANG
REG              REGION
REN              RENAME
-REN            -RENAME
REV               REVOLVE
RO                ROTATE
RP                 RENDERPRESETS
RPR               RPREF
RR                 RENDER
RW                RENDERWIN
S                    STRETCH
SC                 SCALE
SCR               SCRIPT
SE                  DSETTINGS
SEC                SECTION
SET                SETVAR
SHA               SHADEMODE
SL                  SLICE
SN                 SNAP
SO                 SOLID
SP                  SPELL
SPL                SPLINE
SPLANE        SECTIONPLANE
SPE                SPLINEDIT
SSM               SHEETSET
ST                  STYLE
STA               STANDARDS
SU                 SUBTRACT
T                   MTEXT
-T                -MTEXT
TA               TABLET
TB                TABLE
TH               THICKNESS
TI                 TILEMODE
TO               TOOLBAR
TOL             TOLERANCE
TOR            TORUS
TP               TOOLPALETTES
TR               TRIM
TS               TABLESTYLE
UC              UCSMAN
UN              UNITS
-UN            -UNITS
UNI             UNION
V                 VIEW
-V               -VIEW
VP                DDVPOINT
-VP              VPOINT
VS                VSCURRENT
VSM             VISUALSTYLES
-VSM           -VISUALSTYLES
W                  WBLOCK
-W                -WBLOCK
WE                WEDGE
X                   EXPLODE
XA                XATTACH
XB                 XBIND
-XB               -XBIND
XC                XCLIP
XL                XLINE
XR                XREF
-XR            -XREF
Z                  ZOOM
The “dashed” commands open the command line options (no dialog box)
ALT+F8        VBA Run
ALT+F11      VBA Editor
CTRL+1        Properties Palette
CTRL+2        DesignCenter Palette
CTRL+3        Tool Palette
CTRL+4        Sheet Set Manager Palette
CTRL+5        Info Palette
CTRL+6        DBConnect Manager
CTRL+7        Markup Set Manager Palette
CTRL+A        Selects objects in drawing
CTRL+B        Toggles Snap
CTRL+C        Copies objects to Clipboard
CTRL+SHFT+C    Copies objects to Clipboard with Base Point
CTRL+D        Toggles coordinate display
CTRL+E        Cycles through isometric planes
CTRL+F        Toggles running object snaps
CTRL+G        Toggles Grid
CTRL+H        Toggles PICKSTYLE on/off
CTRL+J        Executes last command
CTRL+K        Hyperlink
CTRL+L        Toggles Ortho mode
CTRL+M        (No action)
CTRL+N        Creates a new drawing
CTRL+O        Opens existing drawing
CTRL+P        Prints current drawing
CTRL+Q        Exit
CTRL+R        Cycles layout viewports
CTRL+S        Saves current drawing
CTRL+SHFT+S    Saveas
CTRL+T        Toggles Tablet mode
CTRL+V        Pastes data from Clipboard
CTRL+SHFT+V    Pastes data from Clipboard as Block
CTRL+X        Cuts objects to Clipboard
CTRL+Y        Repeats last action
CTRL+Z        Reverses last action
CTRL+[        Cancels current command
CTRL+\        Cancels current commandSmiley Happy
Message 5 of 10
williamlam02
Thank you very much for the keyboard layout. very helpful indeed.
获得著名风水师收获好运
Message 6 of 10
Why not just use a product like AutoHook to program your existing keyboard?
http://www.command-digital.com/autohook.htm
Works great for hotkeys in AutoCAD. A great productivity booster.
Message 7 of 10
jimbowen
in reply to: command-digital
You have to use our acad keyboard. It sits vertical behind the reg
keyboard in front of your display, it detects your finger optically. So
there is zero pressure, you just tap it. All 90 keys are programmable
at your computer, so one tap can give you a 30 key string, then times 90
keys.
Jim
Message 8 of 10
jimbowen
The EKI keyboard is for professionals, please. How many times do you have to replace the stick-ons? How long does it take when you change PC's, can you use it on Mac and PC, or office to office, or job to job? you have to touch one key to appreciate speed.
Jim
Message 9 of 10
jimbowen
in reply to: IvanShchitov
Transformed, but with no software changes, no optical keyboard?
Message 10 of 10
jimbowen
in reply to: marec2009
Do you do this with one finger, is it optical, can you program a 30 key string on 90 keys?
