Community Classifieds
GeoTools 4.07 - Complete AutoCAD productivity
0 REPLIES 0
Message 1 of 1
639 Views, 0 Replies
G E O T O O L S 4.07 C O M M A N D S S N A P S H O T
GeoTools is an add-on program for AutoCAD 2004/2002/2000i and 2000 and
vertical compatibles.
GeoTools is a productivity tool and helps you finish all of your AutoCAD
tasks faster and efficiently.
Fully functional 30-day evaluation version at
http://www.4d-technologies.com/geotools
GeoTools is fully dialog box driven, 100% icon menu, pull-down menu,
command line and script operable.
This new edition is 100% toolbar, pulldown menu, command-line and script
driven. With this new addition, it is now much faster than ever to
access your tools and this single feature alone can save you over a
hundred or more keystrokes during your work.
Multiple GeoTools interfaces:
- Toolbar pick
- Pull-down menu pick
- AutoCAD command-line
- Automated batch script
Look under the hood carefully. Some tools that you see here may seem to
be already present in your core AutoCAD or in other tools that you may
have used. Don't be misled. In many cases, GeoTools offers you more
possibilities, more options than is possible in ther tools. Check it out
for yourself.
Multiple purchase options: You now no longer need to purchase the entire
toolkit. Our unique 'MyGeoTools' feature allows you to order only the
required tools that you need. Check out this URL for more info:
http://www.4d-technologies.com/geotools/my_geotools.htm
The GeoTools compendium is a quick (we hope) snapshot of tools in the
GeoTools toolkit.
GeoTools Commands Snap-Shot:
Tool # 1 - [Polyline] - Join 3D polylines
Tool # 2 - [Polyline] - Automated join [2d polylines]
Tool # 3 - [Polyline] - Flexible ways to convert 2D-3D and 3D-2D polylines
Tool # 4 - [Polyline] - Specify a new start point for closed polylines
Tool # 5 - [Polyline] - Single pick add-vertex, delete vertex
Tool # 6 - [Polyline] - Convert zero length to points
Tool # 7 - [Polyline] - Identify & Reverse direction
Tool # 8 - [Polyline] - Distance and angle based weeding
Tool # 9 - [Polyline] - Set zero elevations to nearest non-zero value
Tool # 10 - [Polyline] - Populate zero value elevations by linear
interpolation
Tool # 11 - [Polyline] - Label vertices, Label segments, angles. Fully
user customized
Tool # 12 - [Polyline] - Compute summed lengths
Tool # 13 - [Polyline] - Control polyline linetype
Tool # 14 - [Polyline] - Multiple Pedit
Tool # 15 - [Polyline] - Identify zero elevation vertex
Tool # 16 - [Polyline] - Explode wide polylines, retain width geometry
Tool # 17 - [Polyline] - Place Points/Blocks along vertices
Tool # 18 - [Polyline] - Powerful property based filtering
Tool # 19 - [Polyline] - Offset, Move, Extract, Mirror, Rotate, Stretch
part of polyline
Tool # 20 - [Polyline] - Find direction of vertices
Tool # 21 - [Polyline] - Convert arc segments to linear in many ways
Tool # 22 - [Polyline] - Convert from spline, Convert to spline
Tool # 23 - [Polyline] - Compute detailed statistics
Tool # 24 - [Polyline] - Easy 3d polyline
Tool # 25 - [Polyline] - Express Pedit
Tool # 26 - [Polyline] - Highlight elevation differences
Tool # 27 - [Polyline] - Add/Remove closing vertices
Tool # 28 - [Polyline] - Fillet between two polylines
Tool # 29 - [Polyline] - Offset and delete original
Tool # 30 - [Polyline] - Offset closed polylines INwards / OUTwards
Tool # 31 - [Polyline] - Break crossing objects at end of polyline
Tool # 32 - [Polyline] - Multiple Variable distance measure
Tool # 33 - [Polyline] - Multiple Variable polyline segment offset
Tool # 34 - [Polyline] - Convert lines, arcs, circles to polylines
Tool # 35 - [Polyline] - Offset 3d polylines
Tool # 36 - [Polyline[ - Weed (remove) collinear vertices from polyline
Tool # 37 - [Conversion] - Scale Z values
Tool # 38 - [Conversion] - Change Properties ByLayer-to-ByEntity
Tool # 39 - [Conversion] - Convert Blocks/Shapes to Points
Tool # 40 - [Conversion] - Convert Points to Blocks/Shapes
Tool # 41 - [Conversion] - Assign inherited Properties
Tool # 42 - [Conversion] - Assign contour elevations
Tool # 43 - [Conversion] - Change to current layer
Tool # 44 - [Conversion] - 3DFaces to polylines
Tool # 45 - [Conversion] - 3DFaces to polyface mesh
Tool # 46 - [Conversion] - Polyface meshes to polylines
Tool # 47 - [Conversion] - Convert Object Table Data to Xdata
Tool # 48 - [Conversion] - Transfer Object Table Data to Block Attributes
Tool # 49 - [Conversion] - Convert lines, arcs, circles to polylines
Tool # 50 - [Text] - Add Prefix/Suffix to Text
Tool # 51 - [Text] - List Drawing Fonts
Tool # 52 - [Text] - Enclose Text in Box
Tool # 53 - [Text] - Align Text
Tool # 54 - [Text] - Change to upper, lower, mixed case
Tool # 55 - [Text] - Globally modify TEXT/MTEXT properties
Tool # 56 - [Text] - Draw quick auto-incrementing text (running numbers)
Tool # 57 - [Text] - Draw Multiple Text
Tool # 58 - [Text] - Trim characters
Tool # 59 - [Text] - Filter by property
Tool # 60 - [Text] - Round Off Numeric text
Tool # 61 - [Text] - Slide (move) text relative to its rotation angle
Tool # 62 - [Text] - Write Text to File
Tool # 63 - [Text] - Add/Remove underlining
Tool # 64 - [Text] - Consolidate into MText
Tool # 65 - [Text] - Search, Replace and Zoom to Text & Attributes
Tool # 66 - [Text] - Search Blocks for text strings
Tool # 67 - [Text] - Transfer text strings as object data
Tool # 68 - [Text] - Transfer text strings as block attributes
Tool # 69 - [Selection] - Polylines based on derived properties
Tool # 70 - [Selection] - 3DFaces based on derived properties
Tool # 71 - [Selection] - Powerful boundary based object selector
Tool # 72 - [Selection] - Powerful Object Selection Set
Tool # 73 - [Selection] - Find objects in selected Z range
Tool # 74 - [Selection] - Select Current Layer
Tool # 75 - [Selection] - Select Current Style
Tool # 76 - [Inquiry] - Display angle between two lines
Tool # 77 - [Inquiry] - Display info. about polyline bulge (arc segments)
Tool # 78 - [Inquiry] - Compute Center of Gravity
Tool # 79 - [Inquiry] - Display Drawing Statistics
Tool # 80 - [Inquiry] - Compute running distance/perimeter
Tool # 81 - [Inquiry] - Compute summed areas of closed polylines
Tool # 82 - [Inquiry] - Object Selection Browser
Tool # 83 - [Inquiry] - Quick elevation Info
Tool # 84 - [Inquiry] - Display horizontal & Vertical distances
Tool # 85 - [Inquiry] - Find out direction of polyline vertices
Tool # 86 - [Inquiry] - Compute detailed polyline statistics
Tool # 87 - [Inquiry] - Identify objects with vertex elevation differences
Tool # 88 - [Draw] - Helix
Tool # 89 - [Draw] - Parabola
Tool # 90 - [Draw] - Involute
Tool # 91 - [Draw] - Perpendicular lines
Tool # 92 - [Draw] - Box with diagonals
Tool # 93 - [Draw] - Running Numbers Text
Tool # 94 - [Draw] - Multiple Text Insertions
Tool # 95 - [Draw] - Projected (construction) lines
Tool # 96 - [Draw] - Easy 3dpoint
Tool # 97 - [Draw] - Easy 3dpolyline
Tool # 98 - [Draw] - Easy 3dface
Tool # 99 - [Draw] - Draw tangents to curves
Tool # 100 - [Build] - Make right-of-way from center-lines
Tool # 101 - [Build] - Make road center-lines from rights-of-way
Tool # 102 - [Build] - Mulitple polyline offsets - relative / absolute
Tool # 103 - [Build] - Offset and delete original
Tool # 104 - [Build] - Offset, Move, Extract, Mirror, Rotate, Stretch
part of polyline
Tool # 105 - [Build] - Move/Copy and then rotate
Tool # 106 - [Build] - Offset single segment from polyline
Tool # 107- [Build] - Offset closed polylines INwards / OUTwards
Tool # 108 - [Build] - Multiple Variable distance Measure
Tool # 109 - [Build] - Multiple Variable distance polyline segment offset
Tool # 110 - [Build] - Multiple drawing Inserts
Tool # 111 - [Cleanup] - Weed (remove) polyline vertices based on
distance and angle
Tool # 112 - [Cleanup] - Weed (remove) collinear vertices from polylines
Tool # 113 - [Cleanup] - Remove overlapping line segments from a
selection of line objects
Tool # 114 - [Cleanup] - Delete Duplicate Objects
Tool # 115 - [Cleanup] - Delete Null TEXT
Tool # 116 - [Cleanup] - Purge All Unused Symbols
Tool # 117 - [Cleanup] - Linework and Node-work Snap (MAGNET)
Tool # 118 - [Cleanup] - Remove redundant closing vertex in polyline
Tool # 119 - [Cleanup] - Break crossing objects at end of polylines
Tool # 120 - [Blocks] - Place Points/Blocks along vertices
Tool # 121 - [Blocks] - Convert Blocks to Points
Tool # 122 - [Blocks] - Convert Points to Blocks
Tool # 123 - [Blocks] - Globally Modify Block Properties
Tool # 124 - [Blocks] - Extract Block attributes to file
Tool # 125 - [Blocks] - Transfer Attributes between blocks
Tool # 126 - [Blocks] - Explode only nested blocks
Tool # 127 - [Blocks] - Global Attribute Editor
Tool # 128 - [Blocks] - Multiple Redefine of Block definition properties
Tool # 129 - [Blocks] - Replace Block
Tool # 130 - [Blocks] - Explode Block- Retain attributes as Text
Tool # 131 - [Blocks] - Express Block Insert
Tool # 132 - [Blocks] - Search and replace text/attributes
Tool # 133 - [Blocks] - Edit Block graphics and attributes globally and
independently
Tool # 134 - [Blocks] - Insert blocks with auto-incrementing attribute
counters
Tool # 135 - [Blocks] - Edit graphics and attributes globally and
independently
Tool # 136 - [Blocks] - Search Block definition for text string
Tool # 137 - [Blocks] - Define Object table from block attributes
Tool # 138 - [Blocks] - Change attributes to upper, lower or mixed case
Tool # 139 - [AutoCAD Map] - Convert Object Data to Xdata
Tool # 140 - [AutoCAD Map] - Transfer Object Data between two objects
Tool # 141 - [AutoCAD Map] - Transfer Object Data to Block Attributes
Tool # 142 - [AutoCAD Map] - Transfer AutoCAD entity properties to
Object Data
Tool # 143 - [AutoCAD Map] - Transfer Block Attributes to Object Data
Tool # 144 - [AutoCAD Map] - Transfer Database linked data to Object Data
Tool # 145 - [AutoCAD Map] - Create Text Labels from Object Data
Tool # 146 - [AutoCAD Map] - Merge two object data tables
Tool # 147 - [AutoCAD Map] - Remove duplicate object table records
Tool # 148 - [AutoCAD Map] - Export Object Data to ASCII files
Tool # 149 - [AutoCAD Map] - Transfer Text Strings to Object Data
Tool # 150 - [AutoCAD Map] - List Object Data
Tool # 151 - [AutoCAD Map] - Search and replace Object table data
Tool # 152 - [AutoCAD Map] - Select topology objects graphically
Tool # 153 - [AutoCAD Map] - Copy Object Table definition
Tool # 154 - [AutoCAD Map] - Define Object Table from block attributes
Tool # 155 - [AutoCAD Map] - Define Object Table from linked database table
Tool # 156 - [AutoCAD Map] - Global Object Data Editor
Tool # 157 - [AutoCAD Map] - Format text labels queried with 'Alter
properties'
Tool # 158 - [AutoCAD Map] - Auto-Incrementing object data assignment to
objects
Tool # 159 - [Civil Tools] - Annotate surveyed traverse [planimetric]
with chainages
Tool # 160 - [Civil Tools] - Draw cross-sectional profile along a 3d
polyline
Tool # 161 - [Civil Tools] - Draw graded polylines
Tool # 162 - [Miscellaneous] - Control 3dface Face Normals
Tool # 163 - [Miscellaneous] - Draw slope lines between two edges
Tool # 164 - [Miscellaneous] - Object Chopper
Tool # 165 - [Miscellaneous] - Automatic Dimensioning
Tool # 166 - [Miscellaneous] - Export every layer to its own DWG
Tool # 167 - [Miscellaneous] - Match Object Properties
Tool # 168 - [Miscellaneous] - Roughen lines
Tool # 169 - [Miscellaneous] - Compute Surface Area of 3DFACEs
Tool # 170 - [Miscellaneous] - Align Objects
Tool # 171 - [Miscellaneous] - Control 3dface Face Normals
Tool # 172 - [Miscellaneous] - Extract from XREF
Tool # 173 - [Miscellaneous] - Multiple DWG XREF
Tool # 174 - [Miscellaneous] - Multiple DWG Insert
Tool # 175 - [Miscellaneous] - Split drawing using WBLOCK
Tool # 176 - [Miscellaneous] - Sort ASCII files
Tool # 177 - [Miscellaneous] - Draw vegetation cover symbols
Tool # 178 - [Miscellaneous] - Draw Embankment hatch slopes pattern
Tool # 179 - [Miscellaneous] - Fix objects with non-parallel UCS
Tool # 180 - [Miscellaneous] - Import ARC ASCII DEM files
Tool # 181 - [Miscellaneous] - Export ARC ASCII DEM files
Tool # 182 - [Annotation] - Label picked points with XYZ values
Tool # 183 - [Annotation] - Label Polyline Vertices
Tool # 184 - [Annotation] - Label polylines with object / database
linked database
Tool # 185 - [Annotation] - Label Polyline Segments
Tool # 186 - [Annotation] - Label Contour polylines
Tool # 187 - [Annotation] - Label Polyline Angles
GeoTools is only US$ 124.00 per license. Attractive multiple license
discounts available.
Fully functional 30-day evaluation version available for download from
Did you sign-up for the GeoTools newsletter? Be informed and be part of
the development.
Log on now to http://www.4d-technologies.com/geotools
Are you a programmer? Have you visited our TechCenter where you can
download for FREE hundreds of AutoLisp code and build your own powerful
applications and programs.
Log on now to http://www.4d-technologies.com/techcenter
Rakesh Rao
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
0 REPLIES 0
