Community Classifieds
CV Experience in Autodesk inventor (Casting, Product design)
0 REPLIES 0
Message 1 of 1
813 Views, 0 Replies
CURRICULUM VITAE
Sameer Maktumsab Yaligar
        Email ID:-    samiyaligar@gmail.com
Pune-411039
Objective
           To acquire a position in an organization, which gives me the opportunity to utilize and hone my technical, interpersonal and organizational skills.
Academic Qualification
Degree /Course
College/Institute
Board/University
Year of
Passing
Percentage
B-Tech Mechanical
(Correspondence)
YCMOU (MIT PUNE)
YCMOU
2012
Diploma
Automobile Engineering.
Pimpri Chinchwad polytechnic Akurdi Pune
MSBTE
2006
65.52%
S.S.C
Sidheshwar high school Pune
Maharashtra Board
2003
62.93%
Professional Skill
CAD System: Autodesk Inventor 11, (Modeling, Assembly, Surfacing, Drafting)
                     UNGRAHPICS NX-4
           Autodesk AutoCAD,
           Isodraw 5.1
           Trained in BPCS –ERP Software
           Worked on Software like Smarteam PLM Software (User Interface)
Courses
  1. CERTIFICATE IN CAD-CAM INSTITUTE COLLEGE OF ENGG –PUNE.
  2. CATIA-V5 MODULER COURSE IN COLLEGE OF ENGG –PUNE.
  3. MONTH COURSE IN UNGRAHPICS AT KALYANI INFOTECH SOLUTION PVT LTD
      SILICON MEADOWS ENGINEERING LTD. Pune.(ALICON GROUP)
 (Nov 2010- till date)
Work Experience
Silicon meadows Engineering Services Limited is a complete product engineering service provider in CAD & CAE field and caters to the design and engineering needs of firms that wish to attain an advantage in the terms of cost and quality
  1. Working on the mechanical products like Air Compressors and Generators (railway, portable, reciprocating, Screw etc.) (Inventor 2011).
  2. Co-ordinate with the reverse engineering team and convert Un-parametric dump model into parametric Inventor model
  3. To convert un-parametric parts like Impellers with complex blade profile to parametric model
  4. LPDC and GDC Die Casting Die Design (Basic Knowledge)
  5. sModify the parting line according to the customer requirement input as 2D drawing.
  6. Creating and updating the project tracking sheet
  7. Support and guide the team with respective projects and Quires
  8. Communicate with customer regarding quires arise during the project excision.
  9. Working on the complex modeling (Casting like Gear casing, Couple housing, Crank Shafts, Pistons, Impellers, Fan and Casting Parts relevant Automotive and non-automotive parts)
10. Working on Autodesk Inventor 2011 Modules like Part (.ipt), sheet metal, Presentation (ipn) , Assembly(.iam).
11. To fulfill the customer needs spare part book for various customers.
12. Act as a Link between the customer and organization.
13. Coordinating with the team and Distribute the work.
14. Autodesk publisher is also a part of the current work.
Employee of Kalyani InfoTech Ltd Pune (August 2008-October 2010)
ONSITE EXPERIENCE IN ATLAS COPCO (GECIA) Global Engineering Center India Airpower
Major Projects in UnigraphicsS Undertaken at Kalyani InfoTech Solutions
  1. Major Projects Done for Bharat forge Bearing
    1. Cap (forging), Converting non-Parametric in parametric solid (Counter shaft),
    2. Crank shaft for Heavy Motor Vehicle(Kalyani Forge)
    3. Converting 2D to 3D parts like Camshaft, Crankshaft, Cylinder block and various automotive parts.
  2. Creating Volume models for Electrical component.
  3.  Feed check valves ,Gear change Lever Assemblies
Project Name: Bearing Cap (forging)
Costumer Name: Bharat Forge Pvt. Ltd.
Description: Modeling and Drafting
Project Name: Converting non-Parametric in parametric solid (Counter shaft)
Costumer Name: In House Project
Project Name: Crawler Link
  1.  Preparation of spear part books, instruction manuals, flow diagrams, product labels, instruction labels of the products of Atlas Copco like Air Compressors and generators (railway, portable, reciprocating, screw, boosters, stationary).
  2. Preparing the Instruction drawing for the various stages of the Assembly and upload that to the PLM system.
  3. Dealing with the pictures to create the isometric view in isodraw.
  4. Mange the international customer from Atlas copco (China, USA ,Belgium ,etc)
  5.  Technical illustration (isodraw 5.1 and 6) from 2.5 year in Atlas Copco in the GECIA.
  6. Trained in BPCS – ERP Software.
  7. Worked on Software like Smarteam PLM Software.
  8. Handle the Project independently.
  9. Preparing the various flow diagrams and product labels in Isodraw.
  10. Customize the output according to the need of Customers.
  11. Commutating between the international customers.
  12. Also worked in Perform 2D Drawing Ok 3D Ok various Parts and components of Air Compressors.
  13. Volume Models of Various Electrical Parts
  14. Preparing Instruction Manuals, Instruction Drawing Required for Assembly, Assembly
One year Experience in Bajaj Auto Ltd. Pune. (June 2006-July2007)
Profile: - Worked as an Engineer in Engine Assembly Department
1      Worked as an supervisor on conveyer of Wave, K-70 (Discover), Kristal, CT-100 Engine Assembly.
2      To investigate the defected parts rejected in assembly process.
3      Trained in TMP policy of India.
4      Done Number of POKA YOKA and KAIZAN on conveyer.
5      Listing and presenting the production loss.
6      To investigate the Abnormality in the engine and finding the Route causes.
  Academic Project
Major Project            : “BRAKE FAILURE INDICATOR”
Description               : A system that indicates the warning of failure of the brake in case
  Hydraulic brakes
Personal Profile
Name                     :        Sameer Maktumsab Yaligar
Date of Birth            :        30th Dec 1987                                              Languages Known        :        English, Hindi, and Marathi
DATE :-        (Sameer Yaligar)
0 REPLIES 0
