Community Classifieds
Automatic license reports with JTB FlexReport 7.0
0 REPLIES 0
Message 1 of 1
JTBWorld
406 Views, 0 Replies
JTB FlexReport 7.0 comes with the functionality to schedule creation of license usage charts. One usage of this functionality is to create an intranet web page that always shows the usage from the last 7 days for the main features (products) on your license server.
Downloads here. See also the Upgrade tips. Customers with maintenance have access to this release at no extra cost.
See the revision history for more details on this release.
Here is from the documentation of the chart client.
Auto Reports tab
With this functionality you can have reports automatically created as PNG image files at specified recurrence pattern.
This requires that the JTB FlexReport Auto Chart Service is running.
To set up a report first manually create the report you like to use.
Specify the recurrence pattern if the report should be created on an hourly, daily or monthly basis.
Hourly settings allow a report to be created multiple times per hour.
Daily settings allow a report to be created at specified days and time.
Monthly settings allow a report to be created on a monthly basis.
The Settings panel explained.
File Save Path is a path located where the Auto Chart Service is running. You can run this client on any computer but the report file will be created locally on the server. Use Validate Path to ensure it is correct.
If the report should overwrite itself each time use a fixed file name checkbox.
Enter a file name that is the basis for the report file. If fixed file name is not used the file name will have a suffix with the date and time. For example AutoCADperDay (2012-02-13 08.52.12).png where AutoCADperDay is the file name.
Specify also the size for the image.
When ready press Save Settings.
The report will show up on the Report List panel and can also be deleted from there.
JTB FlexReport is a report tool for applications using the FlexNet / FLEXlm (flexlm license manager), IBM LUM (IBM License Use Management), SPLM (Intergraph SmartPlant License Manager), SLM/Sentinel LM/Sentinel RMS, LM-X, Solidworks SNL License Manager, Licman, Primavera from Oracle, Vertex or 12D software licensing as well as any Windows application like Acrobat, Visio, single licensed AutoCAD or AutoCAD LT.
Contact us to get a time limited license file for free. You can try it in your environment with your real data for a few weeks with full functionality.
Full support is provided during trial period.
See also: Autodesk Network License Manager for 2013 products and Software Vendor Audits are Increasing
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
0 REPLIES 0
