I have noticed that when I zoom in or out, it does it to a certain amount as if a "snap" was on. I know the mouse has a button that allows the wheel to spin freely or by an incrament but thats not the solution. Its as if the zoom has a zoom ratio where it will snap to a certain distant. Is there a way to change this?
hi, I may not have the best answer for you but if you type "zoomfactor" and then "enter" it brings up a numerical value to enter, try changing this to 30 then 50 then 80. pick which even numbers you want but it will change the amount of zooming each notch on the wheel does. hope this helps.
