Have you seen this before?
SDI=1 but the drawing path at the top of the window is different than the drawing path under the Window pull-down:
Mark Green
Working on Civil 3D in Canada
The one at the top of the window is the correct drawing path. [Ctrl+Tab] does nothing. There is only one possible drawing because SDI (Single Document Interface) = 1
I did start to open the other drawing shown in the Window pull-down but I cancelled the dialog and did not open it. After I saw what is in the picture I figured it was time to close and restart AutoCAD.
I had switched between SDI=0 and SDI=1 at some point prior to starting to open the other drawing and then cancelling. Idk if that can contribute to the problem.
