Althout I have created the widening on my aliment and used a designer critery on my corridor, I can't achieve that the corridor use the widenig on the curves.
I need that the corridor generate the widening on the curves, I can't stake the corridor without widening.
Please see attached.
Mark Green
Working on Civil 3D in Canada
Did you use a subassembly that has a width target and then set the widening alignment as the target for the subassembly?
As mentioned a subassembly supporting "Target Parameters" must be used and the target must be mapped in the Target Mapping dialog box on "Parameters" tab of the corridor properties dialog.
A subassembly such as LaneSuperelevationAOR has this capability (see "Target Parameters" section).
Also see Setting Targets
corridor properties / parameters / set all targets / width or offsets targets / width alignment left - here you select your left widening if you have one, and the same thing you wiil do for the right side
