question?
I have set up a sheetset that has 82 drawings with sheet names, numbers and fields this took me a week.
The client has come back and said they want us to use their standards and use there standard .dst
Am I able to import my current drawing from the sheetset manager that I created into the clients dst without having to rename and renumber every drawing.
will I lose all my fields currently in my sheetset?
Aaron Apodaca
Jviation Inc.
Solved by Jay_B. Go to Solution.
Solved by MMcCall402. Go to Solution.
A third party such as SSMPropEditor by JTB World may be helpful.
What's so special about their standard .dst? Might be easier to massage your current sheetset to match their standard.
You know I am not sure what so special about their dst? It is for a very big client I just figured I would comply, if I am able to massage the dst I will, I have never had to do this, so I was a bit thrown back on how I was going to accomplish the task.
I will dive into their dst, and I will change all the naming to match theirs once I open up the properties I think if I am able to edit those names I will be good just have to figure if I can do that.
do you know if I can do that?
Aaron Apodaca
Jay,
thanks I figured it out, I had to rename everything and re-due all fields.
thanks I figured it out, I had to rename everything and re-due all fields I actually knew I had to do this but thought there might be a different solution.
thanks for the help.
thanks I figured it out.
the reason why this was so special is that this is a huge client and was just trying to keep their standard .dst into play after playing around with it for a couple of days it was easier to use their standard dst and rename everything other than massage our template I would have had to do that for every sheet created which I believe may have taken longer.
