I have a problem I have been running into recently while using SSM. We have a company standard sheetset and template that gets copied/renamed or saved for each new project. In the sheetset layout we have custom overall project properties such as project name, address, project number etc and sheet specific properties like sheet number, sheet name etc.
The problem is that when switching back and forth between projects I'm working on, the the layouts will take on the overall properties from the other project, the properties in the SSM dialogue box stay as they should, but the words in the layout change Project 1 is now displaying Project 2 even though in Project 1's SSM properties it says the name should be Project 1 and no amount of regenerating fixes it. The layouts have typically been made by copying our company template into the project folder and renaming like: "Project 1 Template" it then starting new drawings from that and "importing layouts as sheets."
I really need to get to the bottom of what I am doing wrong here moving forward to keep this from happening. If I am missing any vital information please let me know and I'll add it to the post.
Thanks!
Solved by strikilis. Go to Solution.
If you go into the drawing and double click on the field then right click to hit edit field you should be able to change where it is taking the information from. If you are switching fields from one job to another that have 2 separate sheet sets then you need to have them both open to make it easier for you. If you go to the field names down to where it says sheet set it'll give you the option to choose where it is taking the information from. I hope this helps if any of this is unclear let me know and I'll try to clear things up.
Do you think you could help me understand why it is happening though? Layouts in some of my drawings pulling the general information from a different sheetset it has never been associated with? It will pull all of the overall "sheetset properties" Like project name and date of project start and the designer name then I have to go in and do what you showed me how to do with the double clicking and right clicking each separate field.
Any help would be really appreciated, thanks!
Joe Bouza
