Civil 3D Forum
sharing civil 3D dwg file
11 REPLIES 11
Message 1 of 12
sacprasanna
830 Views, 11 Replies
How to share civil 3D dwg file with non civil 3D(General autoCAD)  users?
Any idea?
Chamara Prasanna
AutoCAD Civil 3D 2015 SP 1
Sri Lanka
11 REPLIES 11
Message 2 of 12
sboon
in reply to: sacprasanna
Export to AutoCAD - choose the appropriate version.
Steve
Expert Elite Alumnus
Message 3 of 12
neilyj666
in reply to: sboon
But remember this is a one way street - there will be no Civil 3D objects for you to use if you reopen this drawing so exercise caution when sharing drawings that contain C3D objects.
Enabling proxy graphics may be an option but I've never tried this so can't explain any more
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 12
sboon
in reply to: neilyj666
The Export command saves a copy of the drawing, which you can provide to other users or use but it does not affect the original Civil3d drawing.  We often use the export drawing to make a "pretty" version with objects flattened and some of the C3D objects cleaned up.  We send this file to architects and other engineers who need to see how our design relates to their work.
Steve
Message 5 of 12
sacprasanna
in reply to: sboon
It is working.But,
Is there are any object which can't eoport autoCAD? And can i get back to civil 3D from autoCAD.
Chamara Prasanna
Sri Lanka
Message 6 of 12
sboon
All Civil3d objects are supposed to export - but there are often issues.  Locked objects - especially cogo points don't export properly as far as I know.
You can open the exported file in Civil3d, but there will not be any C3d objects in it.  Everything is exploded down to dumb linework, and it isn't coming back.  Of course your original drawing is still available so you can go back to that.
Steve
Message 7 of 12
sacprasanna
I tryed it.But it doen't export surface masks,hidden boundries.
Any solution?
Chamara Prasanna
Sri Lanka
Message 8 of 12
sboon
Nope - you'll probably have to do some cleanup in ACad, trimming contours etc.
Steve
Message 9 of 12
sacprasanna
in reply to: sboon
Yep,So This is time to trim trim and trim
Chamara Prasanna
Sri Lanka
Message 10 of 12
neilyj666
in reply to: sboon
Indeed - I meant that if the OP receives the drawing back with additional info added by a third party he won't have access to the C3D objects (as they won't exist). He will then have either Xref the drawing or copy the added content back to the native C3D model drawing.....
Message 11 of 12
antoniovinci
Without converting anything, you may try this solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16976599&linkID=9240618
Message 12 of 12
in reply to: antoniovinci
Hello, antoniovinci
can u explain me what u mean , I can not find nothing about sharing civil 3d files with person who has only autocad.
Rail Community
