I have transfered over to Windows 7 64-bit and have C3D 9009 64-bit installed. No service packs are installed.
Do the hotfixes and service packs for 32-bit C3D 2009 apply to 64-bit, as well?
there is no civil 3d 2009 64 bit
64 bit was introduced in 2011
DarrenP
Even though Autodesk has both the 32 bit and the 64 bit enablers available, only the 32 bit one works. Because Civil 3D 2009 is a 32 bit application (and therefore is installed under the x86 Programs Folder). Don't waste your time with the 64 bit enabler and if you have already, you will need to uninstall it from your Control Panel - Programs and then install the correct 32bit version.
Although Civil 3D 2009 is officially unsupported on Windows 7 64-bit, you shouldn't have any issues applying the Updates.
Good luck!
