Good morning,
If we have a station equation in the alignment (rail in my case), the sample line function distribution, wont work properly after the station equation.
Any work around?
Hi @jfdecarie what do you mean when you say it does not work properly? Can you show us a screenshot?
regards
Before I use screen cast for demonstration, now I don't no good free video software for Windows 10.
Wen a will install a video software, all will share the issue that I found.
By the way do you now a good free video software for Win 10?
Regards.
I like to use Techsmith Capture, which is a free software for screen capture images and videos: https://www.techsmith.com/jing-tool.html
Hi @jfdecarie, if you use Windows 11, the Snipping tool allows you to record your screen. Hit the windows button and type Snipping, and you'll find it.
Although a video might be clearer, I invite you to post screenshots. As long as you can post pictures and concisely explain what is happening with your sample lines, we can understand the problem and try to contribute to a solution.
Best regards!
