I am trying to produce a Survey Figure Inverse Report from the Survey Command Window, and it keep creating a Fatal Error. I've tried different databases, and restarted my computer. It keeps crashing with this error:
FATAL ERROR: Unhandled Access Violation Reading 0x0232 Exception at ACAD2D2Ah
Has anyone else experienced this, or know how to fix this? Thank you.
What is the exact syntax, your using in the survey command window?
What versions of C3D are you experiencing this in?
Rick Jackson
Survey CAD Technician VI
Does the same thing happen when you add the Figure Name as prescribed but the syntax?
Rick Jackson
